Quantcast Heated Seat repair - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Heated Seat repair
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 11-02-2006, 12:20 PM   #31
nylyon
When I fixed mine last year, there is NO circuit board for the heated part of the seats under the seat. Check for power at the plug and continuity in the wiring.
Karl
2001 Cherokee Limited Patriot Blue *Stock* NP242 4.0 ABS Hidden Hitch, Factory Tow Hooks, Michelin X-Radial
nylyon is offline   Reply With Quote
Old 02-20-2007, 09:41 AM   #32
klennop
Originally Posted by showes
It's me again. I just re-read the thread trying to see if I missed anything. If I'm reading correctly (the info isn't lined up in columns so I'm not sure if I am) when the LO led is flashing (which is the case with mine) it is indicating a "NTC Sensor Value Out of Range".... what does that mean / what do I do?
Has anyone figured out how to fix this problem? I am having this same issue but I don't know how to fix it.
klennop is offline   Reply With Quote
Old 03-01-2007, 11:39 PM   #33
atlas000
Same problem here, 2001 Grand Cherokee, drivers side heated seat switch lights and stays lit for both Hi/Lo but there is no heat. Any solutions?
atlas000 is offline   Reply With Quote
Old 01-23-2009, 04:12 PM   #34
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
I'll put this to use.... some day.
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is offline   Reply With Quote
Old 02-20-2011, 12:45 PM   #35
sw19
After reading all this I'm a bit confused. The heated seats in my '99 Cherokee have stopped working. I'm getting the green LEDs mentioned here. I am getting a solid orange when I turn them on. I checked fuse 18 and it's OK. My powered seats work so that leads me to believe that Fuse 29 is good, correct? So is it the heated seat relay or the seat heat interface module?
sw19 is offline   Reply With Quote
Old 03-04-2011, 03:10 AM   #36
01IAJP
I have an 01 Cherokee LTD. Flashing Hi switch. Maybe I should have just fixed the element but I decided to go with universal ceramic element. I just don't know how to wire in the 2 element wires to the 4 wire prong the original 2 elements went to.
01IAJP is offline   Reply With Quote
Old 11-21-2011, 12:24 AM   #37
tswiers
I just used the tips in this thread to fix my 01 Cherokee/XJ Limited. The drivers side heater was not working and the HI portion of the switch was blinking which indicated the break in the wiring. Sure enough, there was the burn spot just under the front (leg portion) of the seat cover. I cut the little blue wire where it was burned and stripped the end of it and then re-soldered it back onto the larger brown feeder wire which fixed the seat heater, hooray!
While doing this I found out some info on this particular seat heater design.
1. there are 3 zones to this seat heater. One on your back on the vertical part of the seat, one on your bum area and one on your legs reaching out to the front edge of the seat.
2. These zoned elements are actually just a single string/loop of the little blue wire which must be resistive wire that just heats up when current goes through them.
3. If you just connect together the large brown wires at one of the zones (I only did this on the front leg zone which was faulty), this will effectively bypass that zone and allow the other two zones to work. (Handy if you are testing to see if it is just one zone that is defective) - not sure if this could be a permanent fix or if it is safe, but it did make my bum and back zones work before I finally fixed the leg zone.
tswiers is offline   Reply With Quote
Old 12-14-2011, 12:00 PM   #38
SUPRBST
I'm about to tackle this problem in my '00 LTD XJ this weekend (hopefully). I'm getting the flashing hi LED on the driver's side, which seems to indicate a broken/burnt wire in the heating element, which seems to be a fairly simple fix, although time-consuming. The passenger seat appears to work just fine, as it heats up very quickly on a cold morning; it does, however, have a noisy front up/down motor that does not move the front up & down when I try to use it. The rear motor works, and the seat moves forward/reverse under motor power, so any advice on that would be helpful (I haven't searched the forum for the motor problem yet).
Out of curiosity, has anyone tried this replacement heating element set to wire in to the OEM harness connectors?
http://www.amazon.com/Universal-Carbon-Fiber-Heater-Installation/dp/B004GOSJOA/ref=reg_hu-rd_add_1_dp http://www.amazon.com/Universal-Carbon-Fiber-Heater-Installation/dp/B004GOSJOA/ref=reg_hu-rd_add_1_dp
It seems like it might work pretty well as a long-term solution for an OEM heater that has flexed too much to be repaired or as an add-on for an XJ that doesn't have seat heaters already installed.
SUPRBST is offline   Reply With Quote
Old 12-14-2011, 04:09 PM   #39
NHCherokee
For what's it's worth, on my '99 Cherokee Limited, the driver's side seat heater quit working a couple of years ago. The light would come on, on both high & low settings, but no heat. I was told by a local dealer that they couldn't get the replacement element anymore. So... I went to a local auto upholstery shop and they installed a great seat heater for $150. They said they were unable to use the console switch, so they very discreetly mounted a switch on the lower front of the seat. It has both a high & low setting, works perfectly and the interior looks stock. Well worth the money.
NHCherokee is offline   Reply With Quote
Glock Forum
