heat wont get hot just gets warm - JeepForum.com
post #1 of 7 Old 02-10-2010, 12:03 AM Thread Starter
tehmilz
the heat in my 2000 cherokee sport with the 4.0 will only get warm. the temp goes to 195 but the heat doesnt get hot any ideas?
tehmilz is offline
post #2 of 7 Old 02-10-2010, 12:17 AM
jettatdi
1973 FSJ Cherokee
I have the same problem with my 97 Cherokee. Let me know if you find a solution.
jettatdi is offline
post #3 of 7 Old 02-10-2010, 04:28 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
By far, the most common cause of weak heat into the cab if coolant temp is at a reasonable temperature, is a partially clogged heater core.
Running near 200 means that your thermostat is working okay and there is no heater control valve on a 2000.
Verify blend door operation, but suspect the heater core if that checks out.
They sometimes can be backflushed with a garden hose to restore function but if that doesn't work, it would need to be replaced.
Feel both the hoses going to the heater core when the engine is hot. If one is hot and the other not so much, that is proof of a heater core problem. That technique though is not completely foolproof for a partially clogged core.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #4 of 7 Old 02-10-2010, 05:22 AM
superj
until you get it fixed, buy one of those electric heaters that plug into your lighter. they sell them at truck stops by the CBs.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #5 of 7 Old 02-10-2010, 03:04 PM
dirty97jeep
1997 XJ Cherokee
try disconnecting both hoses from the heater core and and if possible hook a hose up to one end and increase water pressure slowly and you should se some gunk and whatnot coming out of the other end.
dirty97jeep is offline
post #6 of 7 Old 02-10-2010, 07:31 PM Thread Starter
tehmilz
i did that to my whole cooling system today dirty97jeep. now the heat gets nice and toasty! thanks guys
tehmilz is offline
post #7 of 7 Old 02-10-2010, 07:41 PM
Smittyman
Haha, exact same thing happened to me. Works like a charm! Glad you got it taken care of
Patriot Blue Y2K XJ. Big plans, small wallet.
http://www.jeepforum.com/forum/f22/00-xj-sport-daily-driver-build-thread-908084-new/
Smittyman is offline
heated seat wont heat 99xjjoe XJ Cherokee Technical Forum 2 03-05-2009 09:58 PM
Heat went out... Blower motor wont work 93cherokee4x4 XJ Cherokee Technical Forum 3 11-16-2008 07:31 AM
No defrost? or heat? not the standard heat problem 580z XJ Cherokee Technical Forum 0 12-30-2007 08:07 PM
wont switch heat vents! Jeeper-Joe XJ Cherokee Technical Forum 3 01-24-2005 10:18 PM
warm but not hot heat outerbanker1 XJ Cherokee Technical Forum 5 01-13-2003 04:20 PM
