Heat doesn't work, in the winter of course. HELP! - JeepForum.com
post #1 of 5 Old 11-28-2012, 02:48 PM Thread Starter
Grizzly944
So my heat does not work, and neither does my A/C. I just replaced my radiator because it was leaking. My Accessory fan does not work anymore. I have a light colored smoke coming from my vents when the vehicle warms up, and when on the highway. Even with the A/C and heat are off. It smells pretty bad. I have read that it could be the heater core, but i've checked out the floor board and its not wet. So if anyone can recommend anything, without me removing the whole dash to fix the heater core that would be awesome! Thanks, and sorry for the paragraph.
Grizzly944 is offline
post #2 of 5 Old 11-28-2012, 03:00 PM
jeepkid03
Winning
jeepkid03's Avatar
A good heater core flush (back and forth) makes a big difference. Lots of crap can build up in there. I used Prestone Radiator flush and it helped. Then a local vintage car guy suggested using Cascade dishwasher soap (the gel kind) and it really cleaned lots of stuff out of the heater core. My heat works much better.
I would try that to get any crap out of the core first. You may have a leak though. Also, does your accessory fan not work due to a bad relay, fan motor, or sensor?
The temp sensor might not be reading correctly which won't turn the fan on at the right temp.
Where in CT are you?
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #3 of 5 Old 11-28-2012, 03:40 PM
rayxjs
My 99 sport heats but don't use it because it smells like exsuoust , live in Pa turn it on for a few min then shut it off , just to take the chill out in the morning.any one heard of this.
rayxjs is offline
post #4 of 5 Old 11-28-2012, 04:03 PM
AZ Jeff
2014 JK Wrangler
If the core is confirmed to be leaking, there is NO WAY to remove it without taking the dash apart to gain access to the heater box and then remove it to remove the core.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #5 of 5 Old 11-29-2012, 06:54 AM Thread Starter
Grizzly944
Thanks, i'll give that a try. And im far away from storrs haha, Plainville
a/c , heat , heater core
