Heat/ac - JeepForum.com
post #1 of 6 Old 10-10-2013, 05:40 AM Thread Starter
troydg
Heat/ac
When I turn my heat on in the morning my jeep makes a very annoying squeaking sound for a little bit on and off until it eventually stops. Anybody know what causes this and or how to fix it? Thanks
troydg is offline
post #2 of 6 Old 10-10-2013, 06:24 AM
CCKen
CCKen's Avatar
Sounds like the blower has gone bad. Fan rubbing on the housing.
My POS 2000 T&C did that. I ended up changing the motor/fan assembly.
CCKen is offline
post #3 of 6 Old 10-10-2013, 06:52 AM Thread Starter
troydg
Is it expensive?
troydg is offline
post #4 of 6 Old 10-10-2013, 08:01 AM
CCKen
CCKen's Avatar
Is it expensive?
Yes. And it is a PITA to change.
Before going any further, do an inspection of the blower fan for Chipmunk bones or their nesting material in the fan.
Do this:
Roll the glove box down. Pull the rubber stops on the glove box hinges down and the box will roll out of the way.
Looking inside the opening you'll see a green electrical connector and a relay. Look to the right of them and you'll see the Recirulation Air Door and its actuator. See pic.
With the Recirc door open you can see the bottom half of the blower fan. If the door is closed, like in the pic, you'll need to open the door. To do so, move the AC/Heat control panel Mode Selector knob to Max AC (Recirculation), see #11 in the pic below.
If the door doesn't open (opens inward), start the engine to charge the HVAC vacuum system, shut the engine down and try opening the door again.
With the door open, look in at the blower fan (with a flashlight) and see if there's any crap in there that would jamb the fan. This includes sealing material from the blower and the door.
Turn the ignition key to RUN, without starting the engine. With recirc selected the blower speed select switch is armed. With the blower speed set at #1 position the fan will rotate at its slowest speed. See if the fan is rubbing and causing the noise you hear. If not, select the next highst fan speed then check it out.
If you conclude that the fan is rubbing on crap in the fan area, you may have to remove the blower assembly to clean it out, then the blower assembly can be reinstalled. If the area is clean but the fan is rubbing on the housing the blower assembly should be replaced.
Check it out and get back with your results and/or with any questions.
CCKen is offline
post #5 of 6 Old 10-10-2013, 08:01 AM
AZ Jeff
2014 JK Wrangler
Is it expensive?
Do a search for "heater blower motor" on some of the auto parts stores websites, such as Autozone. They will show prices and availability.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #6 of 6 Old 10-10-2013, 08:13 AM Thread Starter
troydg
Thanks! I appreciate the help!
troydg is offline
