Heat in '98 Cherokee blowing cold air - JeepForum.com
post #1 of 2 Old 12-28-2012, 01:18 PM Thread Starter
NYRHockey12
I have a 1998 Cherokee 4.0 and I recently replaced the the radiator, however, now my heater/ac only works on the highest setting and in the warm setting the heat is only luke warm for about 5 minutes then it just blows chilly air. Any suggestions on what might have happened to my heat?
NYRHockey12 is offline
post #2 of 2 Old 12-28-2012, 04:29 PM
Saudade
1988 XJ Cherokee
If your fan only works on High, you likely toasted the blower motor resistor. If you search the forum on "blower motor resistor", you'll find a ton of threads.
Make sure your radiator is full. Air gets trapped and can take a bit of running to purge out. If the coolant level is low, you won't get much heat.
Other suspect is the blend door control. Another term to search on.
Saudade is offline
