Headlights are acting in the weirdest way, Help? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Headlights are acting in the weirdest way, Help?
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 12-10-2013, 09:57 AM   #1
Darrian
So the headlights on my 2001 are somehow both working and not working at the same time. They were working just fine up until 3 days ago. 3 days ago they took a minute to come on whenever I pulled the switch. Then on the second day they started flickering on and off a bit while driving but stabilized and kept working. Last night I got in my jeep and tried to turn on my lights but they didn't come on, not even after driving for a minute. However the brights still work if I pull back on the lever. I had googled around and from I could find it just seemed like the turn signal assembly had gone bad. I replaced that but I'm still having the same problem. I checked the fuses in the passenger kick panel and those were okay. I'm thinking the next step is to replace the headlight switch itself. Does anyone know what else I could check for to see if that's an issue?
Darrian is offline   Reply With Quote
Unread 12-10-2013, 11:24 AM   #2
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Any headlight problems should start with the cheap and easy stuff. Test the wire plugs and wires at the headlights with a volts/ohms multi-meter. Check for good ground connections. Check all the fuses, there are 4 of them. Test the headlamps, they both can burn out within hours of each other. Inspect the headlight switch and wire plug, headlight switch problems are common.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 12-10-2013, 01:27 PM   #3
xjdantheman
1993 XJ Cherokee
Should check the for continuity on the low beam at the head light itself. This will tell you if you need new headlights.
xjdantheman is offline   Reply With Quote
Unread 12-10-2013, 03:43 PM   #4
anony
I would look first at the wiring & connections and fuses. Partially corroded fuses and connections often cause lighting problems ... including the 3 pin plug connectors to the headlamps (often become corroded)
What I do if the PDC looks dirty or corroded, is remove all the fuses in the PDC and clean the cavities using elect. contact cleaner then use small amounts of dialectic grease on the fuse blades, sticking each one back into their fuse receptacle.
If you have OE fog lamps there would be another circuit of concern, as the fogs are tied into the headlamp circuit.
Many of the Cherokees have a headlight delay module this too is tied into the headlamp circuit from underneath the dash panel.
Any auxiliary equipment and/or lighting connected to the OE harness can potentially cause problems. What I do to prevent problems is keep all the aux. equipment on a separate battery circuit and fuse panel.
There are numerous accounts of headlight and instrument panel flickering being caused by the headlamp switch.
Are you running standard wattage headlamps using 35 watt primary power or heavier duty lamps with 55 watt primary power?
55 watt primary bulbs are better designed to be used with a min. 16 gauge wire. Aging 18 gauge OE circuits sometime create excessive voltage drop, causing strange things to happen with relays, switches, wiring, etc.
Even when using standard 35 watt primary bulbs ... voltage drop from age, dirt and corrosion the switches sometimes loose efficiency and become problematic. Wear from use & friction is one reason for switch failure ... Also small amounts of arcing over long periods of use (because of poor wiring & connections) produces excessive electrolysis, causing a switch or relay to wear out and not behave as it should. Symptoms e.g. are flickering, switch or relay works intermittently , etc.
Rather than replacing the switch I might try searching for writeups regarding headlight switch rebuilding or maintenance.
e.g. Writeup fixing the headlight dimmer switch.
http://www.jeepforum.com/forum/f11/h...7-xjs-1314610/
or a google search: jeep cherokee rebuild headlight switch
https://www.google.com/search?output...t+switch&btnK=
anony is offline   Reply With Quote
Unread 12-10-2013, 04:21 PM   #5
kevinofhardy
kevinofhardy's Avatar
This sounds similar to what has been happening to mine. They take a few minutes to turn on after I pull the switch on my 99. This happened almost immediately after the temperature dropped down between 0 and 20 f. They do not flicker, but they won't turn on unless the switch has been pulled for a while. I haven't bothered with it because it has always turned on after a few minutes. I do have the wiring harness upgrade and the silver star sealed beams.
Build Thread
kevinofhardy is offline   Reply With Quote
Unread 12-10-2013, 05:37 PM   #6
Jason96XJ
I had just about the same problem. Turned out to be a connector under my airbox
Jason96XJ is offline   Reply With Quote
