Headlight switch and harness melted - JeepForum.com
post #1 of 20 Old 01-18-2010, 06:30 AM Thread Starter
TravisNM
1988 XJ Cherokee
1988 4.0 4WD XJ
My headlights, parking lights, and dash lights stopped turning on.
I checked the fuses and had the 10A parking lights fuse melted in a way that it had popped but still made contact (doh!). I was able to get the headlight switch out to check for burns. What I found were crispy wires and the plug melting into the switch.
I am unable to separate the wire harness plug from the headlight switch so I will need to replace both of them. I've found where to get a new switch. Does anyone know where I can get a new plug? Or do I have to go pull it from a junkyard? I work graves so going to the junkyard is a last resort.
Wires going into melted plug going into headlight switch:
I would greatly appreciate any advice.
TravisNM is offline
post #2 of 20 Old 01-18-2010, 09:54 AM
Holder350
1995 XJ Cherokee
After searching....I cannot find a replacement pigtail for that headlight switch.....
That being said, if you go to the yard to get one, you might as well get the switch there too.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 20 Old 01-18-2010, 12:57 PM
XJNUTTIER
Yeap my 98 did the same thing, and yeap the JY is the way to go for the switch and pigtail. I have done some research and believe that is you add the heavy duty harness even to the stock headlights, you will not only get better light throw, but also drop the current running into the switch thus eliminating future harness issues. Good lucks and hope all works out.
XJNUTTIER is offline
post #4 of 20 Old 01-18-2010, 04:18 PM Thread Starter
TravisNM
1988 XJ Cherokee
Thank you
Once I get the switch fixed I'll be adding two relays to the circuit for high and low beams to avoid this problem altogether in the future.
TravisNM is offline
post #5 of 20 Old 01-18-2010, 08:26 PM
Holder350
1995 XJ Cherokee
Originally Posted by TravisNM View Post
Thank you
Thats a dang good idea....do you happen to be running H4 bulbs or the stockers?
post #6 of 20 Old 01-18-2010, 08:32 PM Thread Starter
TravisNM
1988 XJ Cherokee
I don't know. It has "sylvania performance" sealed lamps. Does that answer your question?
TravisNM is offline
post #7 of 20 Old 01-18-2010, 08:47 PM
compcrasher86
holy moly! Thats what you call defeating the purpose of a fuse. Ummm if even without a fuse you were able to melt the harness, I think you need to look into the problem, there must be a short. Also buy a better brand of fuses if that old one was able to blow like that, that is simply crazy!
Matt
compcrasher86 is offline
post #8 of 20 Old 01-18-2010, 09:04 PM
Holder350
1995 XJ Cherokee
Hmm, must be some good lights.....not the H4 that I was thinking about but I bet they still pull more than the stockers
I have seen this happen before with a properly fused circuit (of course it was with some high power H4 conversions).....its not the fuses fault its the constant pull that the lights put on the switch.....it just generates ALOT of heat.
post #9 of 20 Old 01-18-2010, 09:06 PM
compcrasher86
but shouldnt the wiring be fused accordingly and so the fuse shoulda blown and completely cut off power?!
Matt
post #10 of 20 Old 01-18-2010, 09:20 PM Thread Starter
TravisNM
1988 XJ Cherokee
The fuse did blow. It just blew in a way that it still made contact and allowed current through. I assume that's when the fuse melted. The melted plastic of the fuse was holding it together...epic fail.
Then again I'm not even sure what the 10A parking lights fuse has to do with the headlight switch as that switch gets battery positive via a red wire with a fusible link in it.
TravisNM is offline
post #11 of 20 Old 01-18-2010, 09:33 PM
Holder350
1995 XJ Cherokee
In a perfect world yes....but sadly fuses usually react alot better to a sudden spike in amperage....not go great to the slow heatup of a bulb.
This is why I try try try to get it into peoples heads to use a relay when wiring lights to prevent what you see up there in those pictures.
If you have a wire burn....I would much rather it be in the engine compartment instead of the cab
post #12 of 20 Old 01-18-2010, 09:37 PM
jaunhunglow
the melted connection appears to be the source, probably loose=heat.
jaunhunglow is offline
post #13 of 20 Old 01-19-2010, 11:35 AM
1ATony
Vendor
1ATony's Avatar
I looked on my end for yah too. I have the switch but no pigtail available to offer you.
The dealer might have a pigtail.
SHOP HERE FOR AWESOME
1ATony is offline
post #14 of 20 Old 01-19-2010, 01:09 PM
Kevin108
Wish I'd seen this earlier. I spent yesterday in a local yard and they have 8 or 10 of the 96 and olders.
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #15 of 20 Old 03-13-2011, 10:25 PM
chlag
I Confirm that sylvania performance lamp will melt the light switch. I had to install good old basic lamp to after 2 switches...
chlag is offline
The Definitive Blower Motor blown/melted resistor/switch/wire fix 1995sport XJ Cherokee Technical Forum 34 10-24-2014 10:31 PM
Burning Smell at Night. Headlight Switch or Ignition Switch? 88XJSport XJ Cherokee Technical Forum 12 06-13-2011 11:07 AM
melted fog light switch teamskiawa XJ Cherokee Technical Forum 5 02-08-2010 07:48 PM
My wiring harness melted... itsanthony089 XJ Cherokee Technical Forum 1 10-02-2009 12:15 AM
Headlight Harness Rescue XJ XJ Cherokee Technical Forum 9 08-16-2006 08:16 AM
