Quantcast Headlight Options?????? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Headlight Options??????
Free Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!Rough Country Deals at JeepHut.com
Old 11-29-2008, 10:43 AM   #1
Liveforthegame
I NEED new headlights i can't stand the stock headlights. i want something that will be bright. some thing brighter than the silverstars. i wanted to convert the headlights to an H4 bulb.
Any suggestions on good housings? and where to get them?
Should i go HID?
or just upgrade the watts on an h4 bulb?
Liveforthegame is offline   Reply With Quote
Old 11-29-2008, 10:46 AM   #2
Vassago
The Bike Guru
Vassago's Avatar
H4 with good bulbs and upgrade your wiring.
"He almost broke the land speed record in 1977, popular opinion amongst his team was that his beard caused to much wind resistance. He would have shaved it… No, no he wouldn’t have."
MY BUILD THREAD: http://www.jeepforum.com/forum/f22/build-thread-year-later-01-xj-643365/
My Photography Paul Lehr's Flickr
Vassago is offline   Reply With Quote
Old 11-29-2008, 10:47 AM   #3
Luckyduck
I saw on a Toyota forum a way of making the stock lights brighter. You increase the voltage at the bulb IF the voltage is low. in the example I read the guys lights where only getting 10.6 volts, but with a few relays he got it up to 12.6 volts which yielded something like 80% more light!
Not sure if it works on jeeps but it is an idea
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/
Luckyduck is offline   Reply With Quote
Old 11-29-2008, 10:50 AM   #4
Vassago
The Bike Guru
Vassago's Avatar
here ya go!!!!
http://www.jeepforum.com/forum/2145691-post15.html
http://www.go.jeep-xj.info/HowtoHeadlightLoom.htm
MY BUILD THREAD: http://www.jeepforum.com/forum/showthread.php?t=643365
Old 11-29-2008, 10:55 AM   #5
3xratedxj
IPF headlight housing with any h4 bulb of your choice is by far the best with a wiring harness upgrade
3xratedxj is offline   Reply With Quote
Old 11-29-2008, 11:37 AM   #6
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
E-code lamps and H4 bulbs. http://naxja.org/forum/showthread.php?t=906034. Anything that is fake HID or labeled Crystal lens or Diamond Crystal is just plastic junk. Up grade the wire harness at the same time.
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 11-29-2008, 12:42 PM   #7
Kegan
X2 for IPF housing and their H4 bulbs.
Kegan is offline   Reply With Quote
Old 11-29-2008, 01:40 PM   #8
tangofox007
I have IPF's on two vehicles and Hella e-codes on another. The Hella's have a much better light pattern on high beam. There is not a lot of difference on low beam. The worst combination on high beam is IPF housings with the "Fat Boy" bulbs.
tangofox007 is offline   Reply With Quote
Old 11-29-2008, 05:36 PM   #9
98junk
x2
Hella's have nice flat cut off and nice wide pattern on low beams.
98junk is offline   Reply With Quote
Glock Forum
