headlight failure - JeepForum.com
post #1 of 4 Old 11-30-2005, 01:15 PM Thread Starter
ggottsch
headlight failure
I have a 1996 Cherokee Sport. I have me a little problem with the headlights. They seem to want to randomly short out while I'm driving. It's not the switch. That's been replaced. The dealer has failed to find the problem. Hhhmmmm.
Help me. please?
Gary G.
ggottsch is offline
post #2 of 4 Old 12-01-2005, 12:32 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I would take the headlights out and check/clean the plugs. If they look good, follow the harness and look for any bare wires or spots where it rubs against the body. From there, find the grounds and make sure they are tight and clean.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 4 Old 12-01-2005, 12:56 AM
wolfepack215
wolfepack215's Avatar
1987 XJ Cherokee
Just had the problem on my 87.. Mine was the quick connect from the wire harness just behind the left Headlight...... Corroded all to He!!...... Perfect excuse for the ole' Headlight Wire Harness Upgrade... Now have my 3 feeds (Low, High, Fog) to three 30 amp relays and all shiny new 10 guage wire to my Silverstars.... WOW!! I can see tomorrow from here!!!
wolfepack215 is offline
post #4 of 4 Old 12-01-2005, 04:07 AM
Radiac
Radiac's Avatar
I had the same problem with the flickering on and off on my XJ, It was a loose connection on the 40 amp Maxi-Fuse in the fuse/relay panel under the hood.
I took out ALL fuses and relays and cleaned the contacts, and applied dielectric grease to all connections.
I did clean that connection to the headlights under the airbox when I removed the front end to do my homebrew fix for the sagging driver door. That connection does get dirty.
His: 2006 Bright Silver Commander
Hers: 2004 Bright Silver Grand Cherokee Laredo
Radiac is offline
H4 Headlight Conversions and ARB/IPF H4 Headlight Sytem Wire Loom Upgrade Question speed_BMW330i XJ Cherokee Technical Forum 33 07-22-2014 07:01 AM
ABS failure on a 91 seagrave XJ Cherokee Technical Forum 3 12-26-2009 07:44 PM
TCM to PCM failure howardusa XJ Cherokee Technical Forum 9 06-06-2008 12:12 AM
Headlight failure? Jezzerr XJ Cherokee Technical Forum 6 02-01-2007 07:12 PM
Oil gauge failure RHXJ93 XJ Cherokee Technical Forum 2 08-30-2003 05:18 PM
