Hazard/Safety light issue - JeepForum.com
post #1 of 2 Old 03-18-2017, 08:00 AM Thread Starter
ex4rings
When I put my hazard/safety lights on my left blinker arrow on the instrument panel is the only one that blinks. When I check outside the vehicle all corners blink except passenger side front. When I turn off the hazards, regular blinkers work perfectly as well as the arrows on the instrument panel. I tried changing the flasher relay with no luck. I have not tried changing the bulbs but since they worked fine for the blinkers I did not think that could be the issue. Anyone have any thoughts?
If it matters - '00 XJ
Thanks
ex4rings is offline
post #2 of 2 Old 03-18-2017, 08:47 AM
Ralph77
My '00 might do the same thing. If I don't get the hazard switch in the exact right position when I turn it on only one blinker is blinking on the gauge cluster. Think it is usually the left one. But it never occurred to me that all four still might be blinking outside. Have to check. Otherwise everything else works fine. Thinking it is just the turn signal lever. Since it is just the hazards low on the list to fix. If ever if it continues to work as it does.
Ralph77 is offline
