having issues with stock 95 xj cherokee 4.0 - JeepForum.com
post #1 of 12 Old 11-09-2010, 01:09 PM Thread Starter
floridamud
the jeep: 1995 jeep xj cherokee with 4.0L automatic, 182K miles
here's the problem: every now and then when you get in the car and go to start it it will crank and fire but as soon as you let go of the key it dies, so it turned out not to be the fuel pump, i replaced the filter anyway, now the issues have gotten worse, as stated before they are still intermittant, sometimes it starts like normal, sometimes it doesnt want to, today it refused to start for quite some time, the 30sec trick did not work, nor did rocking the key back and forth between off and accessory, but interestingly right before it finally started while the key was in accessory the check engine light came on flashing, and turned off once the car was started, also it seems when the car does have issues starting after it has started it seems to run slightly rough for about the first 30 seconds then smooths out, no other issues while driving, only the intermittant starting issues, most likely something electrical is my assumption, any ideas?
.... ___ ....................... _______
. /,[___], ..................../__/_,[___],
1---L-OIIIIIIO- ...........1--------L-OIIIIIIIO-
()_) ()_) ---- )_)........()_)--- ) ()_) ---- )_)
floridamud is offline
post #2 of 12 Old 11-09-2010, 02:19 PM
dukie564
1995 XJ Cherokee
so if i understand correctly, if you turn the key and it starts, then let go of the key it shuts off? That's an ignition switch problem - it needs to be replaced
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #3 of 12 Old 11-09-2010, 02:36 PM Thread Starter
floridamud
yes that is exactly what it is doing, can the ignition switch go bad in an intermittant fashion?
post #4 of 12 Old 11-09-2010, 02:38 PM
dukie564
1995 XJ Cherokee
yessir
dukie564 is offline
post #5 of 12 Old 11-09-2010, 04:23 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Agree with dukie. Sounds like the switch. It also appears that it is getting worse.....replace it.
The symptom of "rough running" for the first 30 seconds though, is not related to your starting problem. Always review tuneup hardware FIRST. That involves fresh spark plugs, plug wires, distributor cap, and rotor.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #6 of 12 Old 11-10-2010, 08:31 PM Thread Starter
floridamud
i've had a few people also say crank position sensor, could this be the culprit or is it the ignition switch?
post #7 of 12 Old 11-10-2010, 11:08 PM
egodfrey
egodfrey's Avatar
ignition switch would be where i would start
So many people to thank here's a start to the list
Spidertrax, Yukon, rustys, warn, branik, PSC, advance adapters, Bad wheels, interco, essentially off-road. And many more
Most of all thanks too Ian Johnson and the xtreme off-road crew for all their work, and 4 wheel to heal for their part in it too.
egodfrey is offline
post #8 of 12 Old 11-11-2010, 06:45 AM
dukie564
1995 XJ Cherokee
wouldn't be the crank sensor if it shuts off when you let go of the ignition switch
dukie564 is offline
post #9 of 12 Old 11-11-2010, 06:55 AM
tjwalker
tjwalker's Avatar
Not a crank sensor issue. You have had a flaky ignition switch for a while and it is getting worse...
tjwalker is offline
post #10 of 12 Old 11-11-2010, 07:45 AM Thread Starter
floridamud
ok you guys sound pretty sure! i'll replace it today! thanks!
post #11 of 12 Old 11-11-2010, 08:02 AM
dvonrick
1988 XJ Cherokee
Real cheap thing to try is replacing the ballast resisitor (ceramic thing with 2 wires usually located on driver side fender inside the engine compartment). Usually they aren't intermittent but do cause the failure to run when dropping the key.
dvonrick is offline
post #12 of 12 Old 11-11-2010, 08:09 AM
dukie564
1995 XJ Cherokee
91+ Cherokees don't have ballast resistors
dukie564 is offline
cherokee , starting , starting issue , starting problem , xj
Hey Cherokee owners...Will stock 2005 Wrangler Wheels fit a 95 Cherokee? RedArrow10 XJ Cherokee Technical Forum 3 07-23-2009 11:41 AM
any issues w/ 01 cherokee snow2004 XJ Cherokee Technical Forum 2 03-22-2007 06:37 PM
Swap stock wheels 99 Cherokee to 96 Grand Cherokee?? JeepsJeeps XJ Cherokee Technical Forum 2 10-09-2006 03:41 PM
rubbing issues on stock susp copbait XJ Cherokee Technical Forum 9 07-27-2005 11:13 AM
Cherokee issues, HELP!!! sjns XJ Cherokee Technical Forum 13 01-13-2004 11:07 PM
