Quantcast Have a leaky Injector, where do I find good, but economical, replacements? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Have a leaky Injector, where do I find good, but economical, replacements?
Old 04-23-2005, 04:59 PM   #1
wolfepack215
1987 XJ Cherokee
Okay, just came back from Home Depot. On the way there I ran the vents and had a heavy gas smell. when I got home, popped the hood and #3 injector is leaking from the connection, not the seals.
Question 1: How soon till I go Kaboom?? or can I still drive it?
Question 2: Where do I get good, but inexpensive, replacements?
Question 3: Is bosch as bad as I hear for Jeeps?
wolfepack215 is offline   Reply With Quote
Old 04-23-2005, 05:29 PM   #2
anony91xj
A leaky injector on a 4.0 has the potential to go Kaboom pretty quick if gas hits the hot exhaust manifold. I'd fix this ASAP.
I take it you mean it's leaking where it connects to the fuel rail? Or do you mean the connection to the wire? If it's leaking at the rail, you may just need an O-ring. If it's leaking anywhere else, you need a new injector. Any auto parts store should have an OEM replacement, but injectors aren't cheap. You could also try a junkyard.
I've only heard about problems with Bosch and Jeeps on the Internet, and even then it's only relating to O2 sensors and spark plugs. As for injectors, I have no idea there.
1997 VW Jetta - Daily Beater <---Totaled, seeking replacement DD
2004 GMC Envoy - Wife's Ride
anony91xj is offline   Reply With Quote
Old 04-23-2005, 06:11 PM   #3
cpetey
they want around $75 a piece at the local auto parts store. I found 6 new 19lb injectors and o-rings on ebay for $50 and yes they are bosch. work just fine for me
www.fiveomotorsports.com
E-mail bruce@fiveomotorsports.com
562-867-4999
562-394-7218
90 Lerado, rebuilt 4.0, aw4, 231, RE 5.5, A/A sye, 33" trxus m/t's, lots of other "stuff"
cpetey is offline   Reply With Quote
Old 04-23-2005, 06:45 PM   #4
beavis417
i just had the same problem with mine on the #3 injector. i replaced the o-rings on all the injectors but the #3 still leaked. it was leaking at the top of the injector. the top of the big part like where it is made together. i had to replace the injector. i got a replacement for advance auto for 45.99. not too bad. what have you heard about bosch and jeeps??
[SIZE=3][COLOR=Navy] 1988 jeep cherokee limited, 3" superlift suspension lift, 15x8.5 centerline hellcat wheels, 31x10.50x15 super swamper trxus m/t, $4000.00 stereo system (159.8 db), 160 amp alternator [/COLOR][/SIZE]
[url]http://i40.photobucket.com/albums/e209/beavis417/Copyof1.jpg[/url]
beavis417 is offline   Reply With Quote
Old 04-23-2005, 07:29 PM   #5
JeepCrazyKid
The potential for an engine fire is so great when you have an injector leaking. You should replace it before you even consider driving it again.
Injectors 4, 5, and 6 were all leaking when I got my '87 XJ. Autozone had replacements (new) for me for $42/each.
My advice- Pick up an O-ring kit while you're there and replace the O-rings on all your injectors. You're going to have the fuel rail off anyway and it's a overlooked piece of maintenance. (Remember to dip the O-rings in clean engine oil before installing on the injector.)
Jon
'06 WK
'03 TJ
'98 XJ
JeepCrazyKid is offline   Reply With Quote
Old 05-01-2005, 02:25 PM   #6
wolfepack215
1987 XJ Cherokee
UPDATE!!! I ordered the Injectors from Five-0 motorsports last monday, they arrived regular mail wednesday, I put them in Friday, and you were right, I ended up at the dealer for the fuel line o-ring kit for front and rear of fuel rail. But it was worth it @16.95 each to have no leaking from fuel line. Once put back together it runs smooth and is more responsive, I hope to see some improvements in mileage, but if not, I still am pleased with the overall response gain and smoother running. Not to mention, No KABOOM!!!
Thanks Guys!!
Old 05-01-2005, 02:32 PM   #7
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
That's what I was going to recommend. The ford injector uses a different spray pattern that does well with the 4.0l.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 05-01-2005, 03:43 PM   #8
twisted_ed
yep i installed my 50motorsports injectors and they rock!!
1990 Jeep Cherokee Laredo
4.0L
Automatic Tranny
NP242 Transfer case
Dana 30 front, 35 custom rear differentials
Mods:
RE 4.5" Lift
32x11.50 BFGoodRich M/T KM's
American Eagle 058 Polished Aluminum Wheels, 3.63" BS.
Grand Cherokee Rear Disc Brake setup
Custom Downpipe W/ Cat Removed.
Dynomax Super Turbo Muffler.
Surco Roof Rack
My Jeep
twisted_ed is offline   Reply With Quote
Old 05-02-2005, 10:59 AM   #9
JeepCrazyKid
awesome...thanks for posting the resolution.
Jon
'06 WK
'03 TJ
'98 XJ
Old 05-03-2005, 02:04 AM   #10
88Chief
By ford injector, did you mean the 24lb. Denso Blue Top injectors for the Ford Cobra that are listed under Jeep?
fiveomotorsport.com does seem to have a great price on them.
88Chief
88Chief is offline   Reply With Quote
Old 05-03-2005, 10:21 AM   #11
wolfepack215
1987 XJ Cherokee
The ones I got were the Yellow tip 19lb ford injector. If you need injectors, FIve 0 is the way to go. I got mine two days after I ordered them (not overnighted, just regular shipping), thats CA to FL, all six for 178.10 shipping included. Not bad, definately well worth it.
Glock Forum
