Harmonic Balancer (crank pulley) slight wobble - JeepForum.com
post #1 of 22 Old 09-29-2012, 11:49 AM Thread Starter
calvin196
Is a slight wobble normal with the 4.0 balancer?
01 jeep xj sport
amc242 4.0 i6
The balancer had a wobble befroe and some corrosion on it so I changed it, and yet still a wobble and its been that way for a while, what's the possible cause or causes?
calvin196 is offline
post #2 of 22 Old 09-29-2012, 02:16 PM
BassMasterCHS
1993 XJ Cherokee
Changed it with new one? There shouldn't be any movement at all.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #3 of 22 Old 09-29-2012, 02:19 PM
wgirvine
1992 XJ Cherokee
No, it shouldn't wobble at all. You say you changed it... with what? New part or junkyard?
The road goes on forever, the party never ends....
wgirvine is offline
post #4 of 22 Old 09-30-2012, 09:13 AM Thread Starter
calvin196
I replaced it with a brand new ATP harmonic balancer, stock specs everything. BRAND NEW :P
I installed it properly also replaced woodruff key with brand new one. It's a slight back/forth wobble almost some could consider it a "shake" maybe? Here is a video that resembles what my jeep is doing.
Do keep in mind this isn't my actual video, it just resembles what my harmonic balancer is doing precisely. I see he says he changed his balancer but I've done the same, torqued to spec everything, used puller / presser and the jeep runs great and has no noticeable performance loss at all.
http://www.youtube.com/watch?v=pIy7gF-4Z2o
post #5 of 22 Old 09-30-2012, 09:39 AM
GetLifted
Is it kicking off your serpentine belt? Does it wobble in and out or up and down?
GetLifted is offline
post #6 of 22 Old 09-30-2012, 09:49 AM Thread Starter
calvin196
My serpentine belt is fine, ac engaged etc.. everything is fine, it doesn't seem to actually "move" and I just went outside and recorded this to show you exactly what my pulley is doing,
http://www.youtube.com/watch?v=-O1PWAtKMYY
post #7 of 22 Old 09-30-2012, 10:37 AM
GetLifted
Well about 4 seconds of that video were on the harmonic balancer, and it didnt appear to wobble to me?
Maybe try a minute vid with it fixed on the HB. And throw some serious revs.
If its wobbling in and out of the block, you got crankwalk and your block may need to be replaced. If its off balance (up and down) you may have a bad replacement, bent crank, or severely worn main bearings.
To me: it looked and sounded ok. 4.0s are noisy.
post #8 of 22 Old 09-30-2012, 11:05 AM Thread Starter
calvin196
Ok, yea its just a very slight wobble, if you look at the belt where it leads to the HB yuo can see a wobble in the belt, its like a back/forth but not in / out wobble or up / down its hard to explain, It's a fixed wobble if that makes any sense, I don't see the crank actually moving in any way.
post #9 of 22 Old 09-30-2012, 11:10 AM
GetLifted
If u can, Make another vid of it fixed on the balancer and rev it up.
post #10 of 22 Old 09-30-2012, 12:20 PM Thread Starter
calvin196
I think the slight movement is normal? I found a video of a newly rebuilt amc 242 and there is the same "wobble" on his harmonic balancer as well.
http://www.youtube.com/watch?v=I4kZfPmw2lw
that's the video in reference.
post #11 of 22 Old 09-30-2012, 01:58 PM
GetLifted
i didnt see a wobble in that one either? That vid sounded like a misfire.
Gotta see a video of the HB where the camera is fixed. Moving it around and around makes it impossible to see from my POV.
post #12 of 22 Old 09-30-2012, 04:55 PM
AZ Jeff
2014 JK Wrangler
I did not see any noticeabe wobble from the HB, but the camera kept moving about too much to study it well.
Where is your FAN SHROUD? That a is major help to pulling air through the mechanical fan!!
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #13 of 22 Old 10-01-2012, 02:00 AM Thread Starter
calvin196
The genius that helped me get my hood up snapped it off and said "oops"... Haven't felt the need to get a new one as my electrical fan is non-existent due to that also being improperly re-installed after the radiator was replaced.
Also I do know its hard to study it, but I was trying to get many different angles not knowing which would have been best, also I'm using a hand-held camera nothing fancy and I don't have a camera stand or anything so its hard to get a steady shot of the harmonic balancer. If you really look you can see the slight wobble in the belt as well as the Harmonic Balancer when carefully watching. I am very picky but it is quite a bad wobble to the bare eye, the camera doesn't really do much justice even at 60 fps.
post #14 of 22 Old 10-01-2012, 08:54 AM
GetLifted
you have no fan shroud and no efan
And i went and looked at mine. Its got a very slight wobble, seems to be normal.
post #15 of 22 Old 10-01-2012, 10:02 AM
wgirvine
1992 XJ Cherokee
I got seasick watching that video; keep the camera steady next time. And yes, replace the shroud and get the E-fan working. Unless you want the engine to overheat...
wgirvine is offline
Pulley above the harmonic balancer RitterXJ XJ Cherokee Technical Forum 2 04-29-2010 06:36 PM
Harmonic balancer pulley bolt dieselkiller XJ Cherokee Technical Forum 2 11-29-2008 05:56 AM
Harmonic Balancer, how do I know when it's at the right spot on he crank?? nate438 XJ Cherokee Technical Forum 8 08-02-2008 09:50 PM
Harmonic Balancer/Crankshaft Pulley SlimGoaty XJ Cherokee Technical Forum 7 04-20-2006 05:48 PM
Yikes, crank pulley / harmonic balancer sinking into motor KariGrrrl XJ Cherokee Technical Forum 14 03-29-2006 10:26 PM
