Hard To Start --- Hesitiation - JeepForum.com
post #1 of 8 Old 08-03-2002, 09:40 PM Thread Starter
CruzNlife1
CruzNlife1's Avatar
Causes for both,
i don't care how stupid it sounds toss out every single idea it could possibly be, from the most obvious, to the strangest to the most difficult, thanks =)
1989 Jeep Cherokee XJ LIMITED....2door.... Auto, NP242 4x4...
1996 Ranger Supercab....
1991 Mustang LX....
VERY SOON TO BE A BRAND NEW TJ OWNER, TRYING TO LEARN AS MUCH AS POSSIBLE RIGHT NOW !!
CruzNlife1 is offline
post #2 of 8 Old 08-04-2002, 11:41 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
dying battery, bad alternator, bad spark plug wire, bad spark plug, bad cap, dirty TB, O2 sensor, starter/starter solenoid, corroded battery terminals, bad ignition switch, fuel pump, fuel filter....
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #3 of 8 Old 08-04-2002, 12:22 PM
arpy
try letting the fuel pump pressure up by turning the key to the run position and waiting a few seconds before you turn to the start postition, this often helps with hard starting. For the hesitation, try a good fuel system cleaner like Castrol or Chevron Techron. And as per the previous reply, check/replace the common ignition parts (cap, rotor, wires, plugs, filters etc).
arpy is offline
post #4 of 8 Old 08-04-2002, 02:12 PM
cladinshadow
If there's corrosion on your battery terminals pour some slightly warm baking soda / water mix on your terminals. Make sure your battery caps are closed though, you don't want this stuff gettin into your battery. It'll take care of the corrosion and stain your driveway. =c)
Darren
96 XJ
"Oh, thank god. It's some sort of rescue toaster."
cladinshadow is offline
post #5 of 8 Old 08-04-2002, 08:17 PM Thread Starter
CruzNlife1
CruzNlife1's Avatar
its turning the engine just fine, its just cranks (((fast))) for about 5 full seconds, the battery is fine, its new and the terminals are still shiny with NO corrosion
1991 Mustang LX....
post #6 of 8 Old 08-05-2002, 11:26 AM
lexjeep
lets face it guys, its a jeep thing, this same question was asked about 5 months ago, many people replied saying that the 88 xj to a off the lot 02 xj did it. I cleaned my fule system and turn the key part way before starting and it helps... also pump the gas as its cranking. other than that I'm not sure of what else you can do that will make a difference. tell me if you solve it, but dont kill yourself over it, It makes a jeep have a personality
89 limited xj
3 inch lift, 15X8 rims, 31X10.50 Dueler A/T, New Cherry Red Paint Job, Basic Recovery Items.
Buffalo, NY
http://community.webshots.com/user/lex9258
lexjeep is offline
post #7 of 8 Old 08-13-2002, 03:16 PM
geep
Probably the neutral safety switch
I have the same problem and I have been gettign around it by wiggling the transmission gear shifter. Maybe put it in neutral and try starting it.
If this works, you can get away with it for a while until the neutral switch eventually stops working. I may be close to having to replace it.
good luck
geep is offline
post #8 of 8 Old 08-13-2002, 03:45 PM
dano0o0o
Don't forget about that pesky crank position sensor. As that thing starts to go, it will be harder and harder to start until it's just plain impossible. Hmm...that doesn't really help the hesitation tho.....
dano0o0o is offline
88 4.0L intermittent no start/hard start nglass1219 XJ Cherokee Technical Forum 12 01-25-2012 08:39 PM
Hard Start, No Start, Rough Idle Hillbillydeluxe XJ Cherokee Technical Forum 11 09-19-2008 01:11 PM
interesting hard start/no start/dead battery problem TXjeep97 XJ Cherokee Technical Forum 4 02-18-2008 09:18 PM
Hard start, every day its taking more and more cranking to start. Xride XJ Cherokee Technical Forum 8 11-27-2006 09:20 AM
hard to start after ran hard. The Golden One XJ Cherokee Technical Forum 2 10-21-2004 11:24 PM
