Quantcast Hard start, every day its taking more and more cranking to start. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Hard start, every day its taking more and more cranking to start.
Old 11-25-2006, 03:16 PM   #1
Xride
For some reason of the last week or two its taken longer and longer cranking to get my jeep to start.
It used to be really fast, almost no lag at all, but now its like 5-7 seconds of cranking befor it starts.
I park it in a heated parkade every night, seems the longer it sits the longer it takes to start.
the starter spins fast and doesnt sound like its not getting enough power or anything.
Partsource tested the alt and battery and said both were fine.
Any ideas?
1999 XJ, black, 4x4, NP231 Command Track, 8.25 rear.
3" Old Man EMU, 30" x 9.5" x 15" General Grabber AT2
Xride is offline   Reply With Quote
Old 11-25-2006, 03:26 PM   #2
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
I was having a problem with my jeep starting kind of hard and I used some seafoam in the throttle body and it helped alot
Might try that, i think it was only like $3.
Arcticcat843 is offline   Reply With Quote
Old 11-25-2006, 04:05 PM   #3
Xride
How do I use the seafoam?
I know there are threads on it, but without search its very hard to find for some reason.
Old 11-25-2006, 04:11 PM   #4
Arcticcat843
dakuda is a god
1980 CJ5
http://www.jeepforum.com/forum/f11/sea-foam-99405/?highlight=seafoam
This might help
I just slowly poured it into the throttle body. I think i used about a 1/3 of the can.
Mine started smoking like crazy then it started to idle smoother. Youdo it while it is running BTW. I think you can use it in oil and gas to but i havent done tat yet
Old 11-25-2006, 07:58 PM   #5
Miami_XJ
1995 XJ Cherokee
id like to hear some more opinions on this since my 95 is doing the same thing. my fuel pressure regulator was giving hassle not too long ago, any chance that might be causing our problems?
i ran seafoam not too long ago for what its worth
Miami_XJ is offline   Reply With Quote
Old 11-26-2006, 01:44 AM   #6
Xride
If the fpr was going wouldnt that give me problems all the time ???
How do I check it?
Old 11-26-2006, 11:45 AM   #7
mylt1
you could be losing fuel pressure while it sits overnight. the fuel will drain back into the tank so when you go to start the system has to pressureize first. best thing to do is to check the pressure on the fuel rail to see if it leaks down.
mylt1 is offline   Reply With Quote
Old 11-26-2006, 12:40 PM   #8
smac999
if it is a loss of fuel pressure, then turn the key to on for 5 secs before cranking, the fuel pump turns on and will pressurize the lines. I always start like this anyways.
see if that helps at all
99 XJ classic, 242, upcountry, towing, 8.25 rear w/ trac lock. drop in K&N, hella h4 ecodes
smac999 is offline   Reply With Quote
Old 11-27-2006, 09:20 AM   #9
marioct
same problem
I have the same problem in mt 89 I6. I charge the line by waiting a while with the key on and everything. Sometimes it takes 5 seconds, sometimes pretty quickly.
Anyone know what this is a symptom of???
I thought it just needed a tune up. Plugs, cap, rotor, wires, fuel filter, all changed, no help at all.
marioct is offline   Reply With Quote
Glock Forum
