hard shifting 4x4 - JeepForum.com
post #1 of 6 Old 03-08-2009, 02:10 PM Thread Starter
sasquachYJ
hard shifting 4x4
i test drove a 2000 yesterday and when i shifted to 4 low the transfer case was grinding and wouldn't get in very easily and getting out of 4 low was even harder and it was grinding worse. also the gear indicator(park, reverse, drive, ect.) plate moved and wouldnt stay in place. could it be the indicator that causes the hard shifting, or a bad transfer case or neutral saftey switch? any suggestions
stock 99 for now
sasquachYJ is offline
post #2 of 6 Old 03-08-2009, 02:20 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Shifting into 4-low requires that the transmission be in Neutral and the Jeep is stopped or maybe rolling just a tiny bit (2-3 mph). Transfer cases that are not very often used in 4x4 can be a little reluctant to shift into and out of 4x4. Backing up a few feet after shifting out of 4x4 often helps. Sometimes, the 4x4 shifter lever needs to be adjusted for smooth 4x4 shifting.
CJ7-Tim is offline
post #3 of 6 Old 06-09-2009, 06:53 PM
connor0770
i kinda have the same ?. except when i try to put my jeep in 4hi, i need to go into neutral, and its still hard to get it in there. now 4lo is a whole different story. its nearly impossible to get it into 4lo. and also almost impossible to get it out of 4lo. is this just because 4wd has never been used before i bought it.(previous owner was a freeway driver type deal)
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #4 of 6 Old 06-09-2009, 08:22 PM
CJ7-Tim
CJ7-Tim's Avatar
Probably stiff from lack of use. Lubricate the 4x4 shifter mechanism. When was the T-case fluid last changed ? Make sure the fill plug will come out before you drain the T-case. Re-fill with Dexron-III/Mercon transmission fluid. The 4x4 shifter mechanism may need to be adjusted.
CJ7-Tim is offline
post #5 of 6 Old 06-10-2009, 01:38 PM
connor0770
i have recently changed the t-case fluid with dexron3 but its still shifting hard. not as hard as before but still hard. im thinking im just gna have to put it in and out of 4wd until it loosens up.
post #6 of 6 Old 06-10-2009, 03:41 PM
jkh
So you shouldn't need to back up to get out of 4hi normally? Shouldn't even need to stop? Interesting, I have to back up to get out...
Jason
'98 XJ: UpCountry, bastard pack, 2" spacers, JK shocks, 31" BFG AT's
'81 Honda GL500
Colorado Jeep Club Member #399
jkh is offline
Hard shifting + no shifting = auto tranny issue? DoubleBET XJ Cherokee Technical Forum 7 03-11-2011 08:06 AM
Jerking at 65 + hard shifting = ?? RaccoonJoe XJ Cherokee Technical Forum 2 06-16-2009 10:40 PM
Always Shifting Into 4 Lo This Hard ? twistedgeo XJ Cherokee Technical Forum 3 06-14-2008 02:18 PM
shifting hard. rhino317 XJ Cherokee Technical Forum 5 08-28-2007 08:03 PM
Hard Shifting 96 XJ problem ant_har XJ Cherokee Technical Forum 3 03-26-2005 03:26 PM
