Quantcast H4 conversion, HID conversion, what to do? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > H4 conversion, HID conversion, what to do?
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 10-19-2009, 08:28 PM   #1
mattathayde
ok so seeing as xmas is coming soon i figure i might look towards new head lights for the jeep since even with silver stars at night in the mist i couldnt see crap. so here my question if i switch to H4s i will be able to use those housings (with projectors) for hids correct? and other than the housings and bulbs i just need to swap the harness right?
i would love HIDs but i think if i did it i would have to go to with a very nice kit with high grade components that i just cannot justify the huge cost at this point.
so what h4 housings to look at and what bulbs to look at? is there a good prefab conversion harness of do i just need to make my own?
thanks
-matt
mattathayde is offline   Reply With Quote
Old 10-19-2009, 09:19 PM   #2
LIsurfcasters
h4 conversion
well first you would need to get an H4 headlamp. This might help
http://www.jeepforum.com/forum/f177/h4-conversion-879139/
LIsurfcasters is offline   Reply With Quote
Old 10-19-2009, 09:31 PM   #3
jackdup
Daniel Stern Lighting Consultancy and Supply
you can start by reading stuff on that..there are many different options on headlight upgrades...i was planning a h4 halogen upgrade but then discovered that i could to hids for less cost and better lighting...for halogen most recommend either autopal, hella, or cibie e code housing and some 100 watt bulbs with an upgraded harness...you can buy premade harness or make your own..do some searches and you will soon come up with alot of results..here are a couple good links
FitchVA’s Jeep Page Writeups Upgraded Headlight Wiring Harness
Headlight Loom upgrade
by the way i got these
HID Kits: DDM Tuning - HID Kits, HID Bulbs, DEPO Lighting, BMW and Porsche Performance Accessories
Hella Lighting 003427011 - Hella E-Code (ECE) Headlamp Rectangular Conversion - Quadratec
i heard alot of great things about ddm and they are cheap too..i know its not recommended to put hids in reflective houseings but im going to and aim them right for now..and maybe retrofit in the future when i have time..hope this helps..if you have a more specific question i might be able to answer it
jackdup is offline   Reply With Quote
Old 10-20-2009, 10:26 PM   #4
2doorxj
http://www.jeepforum.com/forum/f177/hids-my-xj-wow-873008/
check out my thread, with the hella housings there isnt very much glare at all.
2doorxj is offline   Reply With Quote
Old 10-21-2009, 08:23 AM   #5
mattathayde
thanks for all the great links guys, now my question is, what is the difference between the 60 buck kit and the 600 buck kit, is there a huge quality difference or is it just the more expensive ones are ripping you off? i would honestly rather put the cash down for something if it is better quality but of course dont want to waste my money either
thanks again
-matt
Old 10-25-2009, 10:46 PM   #6
mattathayde
ok so ive been looking around and have found pretty much everything i need except i am having an issue with the projector issue, i can find H4 housings that fit but none of them have projectors and i cant find much info on projectors. can anyone direct me on that at all? ive found separate projectors but i think they will require a lot of modification of the housing
thanks
-matt
Old 10-26-2009, 08:56 AM   #7
rwilbu01
just get the H4 conversion and harness upgrade. It is cheaper on initial buy and bulb replacement. Not to mention - LEGAL.
rwilbu01 is offline   Reply With Quote
Old 10-26-2009, 09:03 AM   #8
justanotherjpr
I am happy with my Rampage h4 conversion from Jason at Jeepinoutfitters. The autopal H4 lenses can be had for $20 on eBay, then a set of $20 bulbs and the $20 harness from eAutoworks.com will do you just fine.
justanotherjpr is offline   Reply With Quote
Old 10-26-2009, 09:46 AM   #9
440_Magnum
I'd second the advice to contact Daniel Stern. I personally don't think that there are any HID conversions out there that work as well as Cibie H4 lamps and quality bulbs, and Stern has both and the knowledge to get you the right setup.
HIDs may be brighter, but they lack good beam control and tend to cause glare that makes them really ineffective in bad weather. Plus they get really expensive when you have the type that gives you both high-beam and low-beam.
440_Magnum is offline   Reply With Quote
Old 10-26-2009, 09:50 AM   #10
mattathayde
as to the legality, from what ive read in the VA laws, they are fine.
as to the glare a long as you get good projectors that is supposed to correct the pattern and glare, the hids just seem to have a bad rep since so many people toss them in reflector housings
after looking at both of them and pricing it out, i can pa just a little bit more and get quality HIDs that are 2-3 times as bright. i found a place my friend went through that has a bi xeon kit for 125 + 25 shipping from canada, life time warranty on the ballasts. it also has a wiring harness but i am not sure if i can adapt it to work or not. so other than that kit i need to find projectors and housings and maybe a new wiring harness (i was going to make one but honestly for something as important as headlights i dont want to risk getting a bad connection (i trust my wiring but id rather pay a little more for safety)
-matt
Old 10-26-2009, 04:42 PM   #11
popowiecki
i ordered a set of hid lights from hidkits.com the lights work great. but i wish i would not have gotten the lifetime warranty. i called in my order and told them what kind of vehicle i have. they then sent me the wrong bulbs, told me that they would reimburse me for the shipping and handling. they never reimbursed me and they gave me the run around when i wanted to return the bulbs that they said i needed. im just a little nervous that if i need to use their warranty down the road that they wont hold up their end of the deal. but i think the hid lights are the way to go .
popowiecki is offline   Reply With Quote
Old 10-26-2009, 05:35 PM   #12
Sweetlou
I was unable to find the harness you are talking about on the eAutoWorks website. Do you happen to have a link?
Sweetlou is offline   Reply With Quote
Old 10-26-2009, 06:25 PM   #13
mattathayde
do you have projectors?
-matt
Old 10-26-2009, 06:44 PM   #14
popowiecki
no i just have the hella vision plus headlight h4 conversion lenses. they were 45 bucks a piece at oreilly's
Old 10-26-2009, 07:25 PM   #15
mattathayde
dont you have glare issues?
-matt
Glock Forum
