GRRR! Turn signals not working! - JeepForum.com
post #1 of 17 Old 05-31-2013, 11:51 AM Thread Starter
tmsbandman
Hi folks. New to the forum. I have a 99 Cherokee Classic (2WD) and my turn signals have quit working, Hazards are fine.
My first thought was the relay (behind knee blocker.) I replaced it, but no change. Second thought was multi function switch, but that didn't fix it either. Any ideas? Thanks
tmsbandman is offline
post #2 of 17 Old 05-31-2013, 09:26 PM
sbxj
sbxj's Avatar
obviously you checked the fuses?
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #3 of 17 Old 05-31-2013, 11:56 PM Thread Starter
tmsbandman
They had quit working a while ago, and I think I checked them at that time. But I haven't checked since replacing the relay and switch. That would be a big "DUH" moment, but I'd eat a big slice of humble pie to have the problem solved. Is the turn signal a separate fuse from the hazards?
post #4 of 17 Old 06-01-2013, 11:30 AM
sbxj
sbxj's Avatar
According to the manual I saw they share the same 10 amp fuse.
Good Luck.
'01 XJ 2DR Sport
sbxj is offline
post #5 of 17 Old 06-01-2013, 11:36 AM Thread Starter
tmsbandman
Yeah I saw that, too. Hazards are fine, so it's still a mystery.
post #6 of 17 Old 06-02-2013, 09:30 AM
mickc9129
My '91 has two flashers under the dash. One for hazard the other for turn signals. Thought I had to replace the turn signal flasher the other day but found out by wiggling it a little it made new contact and was OK.
mickc9129 is offline
post #7 of 17 Old 06-02-2013, 06:48 PM Thread Starter
tmsbandman
Hmm.. Thanks. Anybody on here know if that's true on the 99?
post #8 of 17 Old 06-02-2013, 06:55 PM
Nick05
1994 XJ Cherokee
my wife's zj did this. we had to replace the switch itself(on the collum). it was easy, three torx to remove cover, one with a hole in the center to pull switch off. if you do this and it has airbags, make sure you disconnect the battery. when we did this, they didn't work for a few miles, but once i drov about 2 miles, they were good.
Nick05 is offline
post #9 of 17 Old 06-03-2013, 05:07 AM
bamasteeler
2 fuses for system:
15 amp fuse in pdb #23 is for flashers
10 amp fuse in junction block #12 for turn signals
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #10 of 17 Old 06-03-2013, 02:46 PM Thread Starter
tmsbandman
Junction block? Under the hood, or passenger kick panel? Or are there fuses elsewhere. I visually inspected every fuse in the two I mentioned.
post #11 of 17 Old 06-03-2013, 03:09 PM
bamasteeler
Junction block is passenger kick panel, PDB is just aft of battery
1980 Jeep CJ7
1999 XJ CLASSIC
post #12 of 17 Old 07-15-2013, 09:48 AM Thread Starter
tmsbandman
ignition lock cylinder?
Still needing to get this fixed. Hven't messed with it in a while but I need this vehicle running. I found a service manual online that has a lot of detailed information about which wire powers what. I see that there are two circuits supplying power-an unswitched one for flashers, and a switched one for TS. I HAVE been having some trouble with my lock cylinder. Sometimes I turn it off, and it's still powering stereo, windows, etc. Could THAT be the problem?
post #13 of 17 Old 07-15-2013, 10:05 AM Thread Starter
tmsbandman
I should say that everything works except turn signals...and intermittently the door locks.
post #14 of 17 Old 07-15-2013, 05:04 PM
bamasteeler
That sounds like your ignition switch or the linkage from your key cylinder to ignition switch mounted on steering column. Could be the inside of your lock cylinder is worn out....
1980 Jeep CJ7
1999 XJ CLASSIC
post #15 of 17 Old 07-15-2013, 05:05 PM
bamasteeler
Not sure on door locks, that is separate system all together, your turn signals is one big gang of contacts in the switch in the column
1980 Jeep CJ7
1999 XJ CLASSIC
turn signal
