#1 | |
Ground strap
I just noticed I forgot to install the ground strap that goes from the back on the engine to the firewall... Could this cause any problems?
#2 |
Yes it can... Anything from radio static, computer glitches all the way to rapid corrosion ( electrolisis) of the cooling system.. And for the 5 minutes that it takes to put back on, it's worth the hassle of one less thing to trouble shoot later if you do start having problems
99 XJ sport, Black, 4 door, 4 litre, 4wd Black Jeep club member # 99 ASE Certified and professional Auto technician 12+ years Every rose has it's Thorn, every XJ has it's leak, and every cowboy sings a sad sad song |
#3 |
So that could be the culprit for the computer problems I'm having?
#4 | |
-John 1996 Jeep Cherokee 4.0 HO Coming soon to a mountain near you! |
#5 |
My rule number 1. If the factory put it on. It's there of a good reason.
#6 |
Where exactly is the ground strap located in the engine compartment?
#7 |
Very back of the engine block, should be attached to a stud on the back of the block, and runs from there to the firewall.
#8 |
yep u need that... also its really not enough for a ground if you put on any accesories like sterios and lights, make a big *** ground cable to go from the battery to the frame that way you know u have a good groung
1990 Jeep Cherokee Laredo 4.0L Automatic Tranny NP242 Transfer case Dana 30 front, 35 custom rear differentials Mods: RE 4.5" Lift 32x11.50 BFGoodRich M/T KM's American Eagle 058 Polished Aluminum Wheels, 3.63" BS. Grand Cherokee Rear Disc Brake setup Custom Downpipe W/ Cat Removed. Dynomax Super Turbo Muffler. Surco Roof Rack My Jeep |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
