Quantcast Grinding noise with RE 3.5" lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Grinding noise with RE 3.5" lift
Old 02-15-2009, 11:37 PM   #1
Scurvydog
Howdy all,
Well my first project on my 99' XJ and I installed a RE 3.5" lift plus front set (Upp/Lwr) of control arms. Running 31" BFG M/T tires.
When I test drove it at street speeds I get a grinding noise from the front driver side only when I decelerate. Pretty sever sounding. I popped it into the alignment shop just up the street and no improvement. I threw in a t-case drop of about an inch. It's quieter and only shows up now say above 30mph. But, hey grinding sounds can't be good
I am guessing it has to something with the front drive shaft? Any thoughts? Is this indicative of needing a SYE? This is my first lift so it's all new to me.
Cheers!
-R
Scurvydog is offline   Reply With Quote
Old 02-16-2009, 03:18 AM   #2
cliffbong732
Have someone stand on the side of the road and drive past. Maybe they can help narrow it down. Check for new shinny scrapes on the under body or anything out of the ordinary. Its good possibility its coming from the drive shaft and maybe rubbing against the exhaust.
cliffbong732 is offline   Reply With Quote
Old 02-16-2009, 06:12 AM   #3
bssmith1220
My jeep and a friends with the same lift do the exact same thing....I have ultimatly decided its from not having a SYE and the driveshaft making some sort of noise. We have both driven like that for several thousand miles and haven't had any adverse effects.
RE 3.5" superflex, 31x10.50 BFG all terrains, front aussie locker, C4x4 tow hooks, Factory front skid and t-case skid
bssmith1220 is offline   Reply With Quote
Old 02-16-2009, 07:39 AM   #4
LeeBee
I have the same issue with my 99 xj, 3.5 RE lift, 31s, sye, new tie rods all around, new steering damper, new steering u joints, new sway bar, tracking bar, new brake pads, and rotors. Havent changed the wheel bearings, but I checked them and they seem fine. I'm running out of ideas as to what this grinding is. I've noticed that the grinding is slowly getting worse over the last few months. I'm about to take it to an exclusive jeep shop that I found when I save some money, to see if they can figure it out.
keep on searching!! Good luck.
"Practice technique my friend, and speed will come."
LeeBee is offline   Reply With Quote
Old 02-16-2009, 10:09 AM   #5
Scurvydog
Well I looked underneath this morning and no obvious scrap spots or rub spots.
When I took it in for alignment the sheet says that my castor is at 4 degrees and it lists 5-8 as the factory spec. Do you think a few degrees off could cause this?
I will add some more lubricant to the front shaft as well.
LeeBee you put in the SYE and still no love huh?
Old 02-16-2009, 10:12 AM   #6
the6nightmares
ahh the joys of tracking down the demons of aftermarket equipment!
Baltimore County Jeep Club
"A squid eating dough in a polyethylene bag is fast and bulbous. Got me?"
the6nightmares is offline   Reply With Quote
Old 02-16-2009, 10:16 AM   #7
Scurvydog
Hhhmm. Am I correct in that a SYE only addresses the rear drive shaft angle? So if my grindy noise is coming from in front of the t-case than an SYE won't help?
Old 02-16-2009, 11:14 AM   #8
WHITEXJ7
My last Cherokee with a 4.5 inch Rock Krawler lift did the exact same thing and my current cherokee with a 3.5 RC does the same. Its right around 30-40 ish, when you let off the gas. I still havent found out what the problem is.
WHITEXJ7 is offline   Reply With Quote
Old 02-16-2009, 11:25 AM   #9
Scurvydog
A suggestion on another thread was to put my jeep up on jacks and run it to see I can better isolate where the noise is coming from. Could be the one of my front wheel bearings. Maybe the lift and bigger tires stressed it out.
Old 02-16-2009, 12:51 PM   #10
dirt4900
1994 XJ Cherokee
anyone seen Ferris Bueller's day off??
JEEP - Just Empty Every Pocket
dirt4900 is offline   Reply With Quote
Old 02-16-2009, 12:53 PM   #11
Dew159
1988 XJ Cherokee
yeah...LOL def don't do that
Dew159 is offline   Reply With Quote
Old 02-16-2009, 02:36 PM   #12
Scurvydog
Yeah as I was eating lunch I was thinking about the wisdom of putting it up on jacks. Maybe lack of. Anyone have some alternative ideas of determining if the sound is coming from drive shaft or not?
Old 02-16-2009, 02:59 PM   #13
Ben824
1997 XJ Cherokee
Remove the front driveshaft and see if the noise goes away. If it does then u know where to start from. I did this when the CV joint in my front driveshaft went bad and sure enough as soon as the shaft was out the noise went away.
Does the noise sound like an angry bird by chance? Thats what mine sounded like when my CV joint went bad. Pretty common problem with pretty much the exact same noise across the board.
http://www.stu-offroad.com/axle/driveshaft/driveshaft-5.htm
This is a great write-up on how to change the CV out. Its not very hard. If you can handle changing a U-joint then you should be able to handle this. I knocked mine out in about an hour.
Hope that helps!
Ben824 is offline   Reply With Quote
Old 02-16-2009, 03:25 PM   #14
skip11and1
Same thing on mine doesnt happen all the time would like to know what you find out
skip11and1 is offline   Reply With Quote
Old 02-16-2009, 03:44 PM   #15
Paradise XJ
Consarn it!!
Paradise XJ's Avatar
1990 XJ Cherokee
Howdy all,
Cheers!
-R
Could it by any chance be your front coils rubbing on your sway bar. Did you put in extended links with that lift. Check the proximity if the coils to the sway bar.
I have 2 RENIX 4.0 Jeeps
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Originally Posted by fedx95 View Post
Try grabbing it and yanking and see if theres any play.
Paradise XJ is offline   Reply With Quote
Glock Forum
