#92 |
Daystar makes extendo's for not too outrageous. If it were mine, I'd get 'new' stockers from a JY and homebrew the bump stop plates on the U bolts. I did mine this weekend, I'll shoot you some pics of it later.
#93 |
Yea, I know what you're talkin about...FitchVA did a nice homebrew bumpstop that I liked...Also the front Driver's side is starting to dry rot too
My XJ rolled out of the factory on a friday thankfully haha
'99 XJ Sport MY BUILD Thank You Hooligan!!! XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA! |
#94 |
I think mine is pretty much the same as FitchVA's. 2x2 tubing with the bottom cut out, ends tapered up, drilled for hockey pucks and welded to the U bolt plate.
#95 | |
I should prob do that while I have the D44 spring plates off. Something else to add to the list ![]()
#96 |
Took about 30 minutes to cut the 2x2 channel out with a 4.5 grinder. No vice so I used my hitch.
![]() ![]() ![]() Welds left boogery because I'm lazy and don't feel like grinding them smooth. Painted with flat black after the pics. Edit: I cut them about 8.5" long. Sat one end flush on the U bolt plate, marked the other end where the overhang began, then scribed a line to taper it off. Shotgunned, mostly. |
#98 |
Ruff Stuff 3/8" plates and 5/8" bolts. I bent the stock 1/4" spring plates tightening down my u-bolts with the stock tire iron, so I decided I needed something beefier. If you get these plates, and U bolts, the nut size is 24mm or 15/16". Get the right size wrench early.
#99 |
you have a great looking rig!!
why are you selling your d44 i read the whole thread I guess I missed it..
>Dirty Betty 01 XJ< Wrecked. >Blue Lucy 97 TJ< Sold. >STACY 99 WJ<Weekend Warrior. >Austin Cityprofile.< Check it out. ΜΟΛΩΝ ΛΑΒΕ! Xbox live Gamer Tag : BMW Alive 01XJ Former Nightcrew member #266(RIP 01/28/09 - 07/22/09) www.nightcrew.org JFI member #2 |
#100 |
Under Construction
He found a second one.
#101 | |
Hopefully getting the ZJ brakes either today or tomorrow just an FYI
#102 |
For your next project..
![]() /pics of my rig in your thread |
#103 |
Im not gonna lie, but i think doorless is kinda stoopid lol
i mean, if it was trail rig, I could maybe see it...but...idk kinda fugly even on Wranglers but that's just my opinion
#104 |
lol to each his own. Picked up an extra set of hood vents at the JY if you are interested, btw.
#105 | |
Under Construction
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
