Quantcast **Greenmachine build** - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > **Greenmachine build**
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 07-23-2009, 01:46 PM   #76
justanotherjpr
Originally Posted by basso4735 View Post
now that you say that you'll probably have to take out the console soon lol.
No kidding!!
justanotherjpr is offline   Reply With Quote
Old 08-03-2009, 03:52 PM   #77
99Greenmachine
D44
Sorry guys for the hiatus...i only have 2 weeks left before college
in the absence period a few things have happened...
1) We sold our other house
2) Been on vacation
So...got back to the D44 today...started grinding it with a wire wheel...here are some pics...Rust wasn't too bad...only on the pumpkin and axle tube ends really.
This is just to show some of the rust on the ends...
Got happy with scraping some of the crud out with a screw driver
These nooks and crannys could not be reached with the wire wheel
There's still a lot to do...there's a lot of surface area on these bad boys
Ok, so a question for you guys...do you think I should raise the shock mounts while I've got the thing off? I'm thinking of this...
http://jeepforum.com/forum/showthread.php?t=736516
Would this be a good idea or should I just leave the stock location alone? I figured this would be a cheap mod...what do yall think?
'99 XJ Sport MY BUILD
Thank You Hooligan!!!
XJ/TJ Heaterbox Seals for sale!!! NIB! Official Mopar made in USA!
99Greenmachine is offline   Reply With Quote
Old 08-03-2009, 04:00 PM   #78
justanotherjpr
Absolutely raise the shock mounts, or your axle tube may end up like this:
this used to be attached there:
Definitely recommend just cutting the stockers off then trimming to be shorter and re-welding like that write-up shows. I have a set of double shears a friend welded on for me this weekend and mounting the shocks is a total PIA now.
Old 08-03-2009, 04:15 PM   #79
99Greenmachine
So wait...shock mounting is worse? Would I still have to use OME Long Travel shocks?
Also, they must be Perpendicular to the leaf spring mount correct?
Old 08-03-2009, 04:32 PM   #80
justanotherjpr
Not sure I understand the bolded part. Shock mounts that hang down are liable to be torn off. Raise them and keep them safe.
I have these on the axle tube and do not recommend them. Because the bolt pases through the bracket, then the bushing, then the bracket again, it is double shear. The shock is difficult to mount. Stock style with a stud and a nut (single shear) is much easier.
Old 08-03-2009, 04:35 PM   #81
99Greenmachine
i meant actually putting the shock on...your post above thoroughly explains it
im gonna leave it single shear for now. I think just being raised will help mucho on the trail
Thanks...
Old 08-03-2009, 04:45 PM   #82
justanotherjpr
Mounting the shock is now a total PIA. Takes about 5 minutes of wrestling the shock when it used to take 15 seconds.
Edit: I will eventually cut these brackets off and go back to a single-sheer type setup.
Old 08-03-2009, 05:23 PM   #83
99Greenmachine
What I ended up with...
Still need to cut off the mounts and have re-welded on...haha that should be fun seeing as how I don't know how to weld
The studs need to get knocked out and the ends need to be cleaned up...that's about it. I'll go over it with the mouse right before I clean and paint.
I'm heading to the beach again tomorrow...but this time I'm also picking up some 4.56 gears for this bad boy . I'll also be picking up my D35 Disc brakes later in the week so HOPEFULLY should be working on that this weekend.
Old 08-03-2009, 05:48 PM   #84
justanotherjpr
Looking great! I painted both my axles with cheap flat black from Wal-Mart for .96 each. The stuff sticks pretty good if the surfaces are clean, touch ups are easy and cheap. So far, its hanging on just as good as the hammerite on my rails, stiffeners, and bumpers.
Old 08-03-2009, 05:53 PM   #85
99Greenmachine
Well, I'm going to spray it with self-etching primer then with a top coat of flat black Rustoleum...I'm not big on glossy looking stuff. Plus, when I get my Riddler diff cover, I'm going to have that looking nicer than the housing haha.
FitchVA, im doing burnt orange/black scheme (sound familiar ) on my diff covers...i can't wait
Old 08-03-2009, 06:37 PM   #86
cornbrizzle
1992 XJ Cherokee
ruff stuff double shear all the way
I run them and I would recomend them (double shear ) any time over single shear stock mounts . mine are easy to change shocks maybe not as fast but a whole lot stronger ,weld a nut on the back side so all you have to do is run the bolt thru and tighten, a whole lot stronger and I hope thats what you are aiming for !!! while you have the rear end out and spending that much time on it don't mount the single shear
just my .02, but it's your jeep do what you want
Brizzle
cornbrizzle is offline   Reply With Quote
Old 08-03-2009, 06:38 PM   #87
justanotherjpr
I have only mounted shocks once in my new ruff stuff double sheers and it was HORRIBLE. Maybe I'm just a wuss?
Old 08-04-2009, 09:47 AM   #88
RockRodHooligan
Under Construction
RockRodHooligan's Avatar
1989 MJ Comanche
Just a recommendation, but I'd do semi flat over flat, for one reason.... it doesn't hold dirt nearly as bad. I've got a buddy with a TJ and Tube fenders that he wanted me to paint flat black(I tried to talk him into semi flat too), but now he's constantly complaining how dirty it always looks. Besides it's a 44, you WANT people to see it!
As for the shock mounts, I've got to say stay single sheer. It's easier to put shocks in and it still allows the shock to pivot correctly with the axle(better for the bushings). I'm going with JKS on the MJ44, since I don't have shock mounts to work with.
http://store.jksmfg.com/merchant2/merchant.mvc?Screen=FAB_922&Store_Code=JKS01&Categ ory_Code=FABParts
Penis inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
I seen a frog once that ate a rolypoly that locked onto it's tongue and I rescued it from starvation by removing the rolypoly.
RockRodHooligan is offline   Reply With Quote
Old 08-05-2009, 08:46 AM   #89
99Greenmachine
Hooigan, I'll probably do the semi-flat now that you mention it
I've seen those JKS shock mounts before but I still think that I'm goin with the homebrew kind haha
Went to the beach yesterday and in addition to having a good time, scored these Yukon 4.56 gears for $115 NIB!!!!
So now this axle build is OFFICIALLY LEGIT
Old 08-05-2009, 08:50 AM   #90
99Greenmachine
Brizzle
Thanks, for your advice, but I'm sticking with the single shear. I really don't envision me breaking a raised single shear mount...the welds will prob break off first
Glock Forum
