Greasing the slip joint on 97+ XJ's(Write-up) - Page 9 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Greasing the slip joint on 97+ XJ's(Write-up)
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 01-23-2012, 07:53 PM   #121
Camfam07
Originally Posted by XJ Xtreme View Post
96+ do. Pre 96 are self lubed by the atf in the t-case.
So mine Being a 1996 and the door says 1995 is this something I should be concerned with?
TITLE SAYS 1996, its a Cherokee country model, I get the clunk kinda feels like a down shift when slowing down a hard downshift it feels like, but I bet this has never been done on mine before.
Camfam07 is offline   Reply With Quote
Unread 01-25-2012, 10:05 AM   #122
Jmccool03
Sorry if this has already been covered, I didn't see it anywhere.
Is this something I should do on my 2001 2WD xj? I don't have the rubber boot, but my slip joint looks the same. I recently replaced my u-joints, and noticed the slip yoke had a little ATF on it but no noticeable grease. Does the 2WD transmission lubricate the slip joint or should I pack it with grease? Thanks for any help.
Jmccool03 is offline   Reply With Quote
Unread 02-08-2012, 05:10 AM   #123
jibbsnow420
good write up!
jibbsnow420 is offline   Reply With Quote
Unread 03-01-2012, 10:15 PM   #124
ChristianAvo
1997 XJ Cherokee
Excellent instructions. I just fixed mine tonight as a matter of fact.
ChristianAvo is offline   Reply With Quote
Unread 03-03-2012, 10:31 PM   #125
lathode
Just bought these to use for the boot. http://www.harborfreight.com/3-16-in...ies-92515.html Seems like they should work pretty good. Plus there will be plenty extra left over for the future.
edit: those did not work, couldn't get them tight enough. Bought some heavy duty zip ties and used those instead. Shifts are definitely smoother now, also no more thumping on take offs.
lathode is offline   Reply With Quote
Unread 04-16-2012, 06:50 AM   #126
rmconner80
XJ Cherokee
Great write up... Fixed mine this weekend (2001 Sport)
"A noble spirit embiggens the smallest man" -Jebediah Springfield
rmconner80 is offline   Reply With Quote
Unread 04-17-2012, 06:59 AM   #127
Pats94
Why not drill it and fit a zerk fitting? And lube it at every oil change?
If its stock it sucks and if it scares the hell outta ya its just about right!
Pats94 is offline   Reply With Quote
Unread 04-19-2012, 07:19 AM   #128
dav5942
dav5942's Avatar
Did mine yesterday-it got rid of the loud clunk but now have two lesser clunks/squeaks.
Rubicon-a point of which any action taken commits the person taking it to a further course of action that cannot be avoided!
dav5942 is offline   Reply With Quote
Unread 06-02-2012, 05:43 AM   #129
eternalfriday
Great thread. Thank you so much for this. I would never have attempted it without reading this first and best of all.......It freakin works. 5/16 is the socket size. Swivel head would be good because two of them are hard to get to. Dont be afraid to tap the driveshaft with the hammer....it comes right out and before you know it your holding a big hunk of metal in your hands thinking Oh crap, I hope this goes back together. No worries, it does easily. Plastic zip ties work for the boot. It feels good to fix something yourself. Even did the new liftarm struts.....super easy and best price is on ebay....strongarm. Now I will tackle the sparkplugs. 2001 Cherokee Limited.
eternalfriday is offline   Reply With Quote
Unread 08-23-2012, 08:02 PM   #130
straightsixjeep
Bump for good info. Now I know the boot is supposed to be clamped, Im missing the clamp closest to the t-case. I went and bought a locker to replace the gears in the diff where this could be the issue right here. I greased up the slip yoke when I did new u-joints last month however I didnt use as much as you and the boot not being clamped leaves the splines wide open. The grease seemed to really help for a few miles.
straightsixjeep is offline   Reply With Quote
Unread 09-03-2012, 07:48 PM   #131
roblaza
EPIC. I really believe this should be a sticky...It has made my to-do list, right near the top. Thanks!!
roblaza is offline   Reply With Quote
Unread 09-03-2012, 08:56 PM   #132
straightsixjeep
Remember to let the vehicle cool off if you just drove it, I got real excited to take the DS off to grease it after a cruise. I heard a sizzling, took a sec before I realized it was my hand on the blazing hot muffler. A nice battle wound to the collection.
Unread 09-03-2012, 10:42 PM   #133
gcy24
old thread but solid info.
1999 Cherokee classic- 3" RC lift with 31" Firestones.
selling "snowflake" 15x7 wheels with 225/75/15 tires, pm me.
gcy24 is offline   Reply With Quote
Unread 01-12-2013, 07:37 PM   #134
NewLegs
Are we talking the same antisieze I would use on the threads of problem bolts? like that permatex copper coat antisieze stuff?
NewLegs is offline   Reply With Quote
Unread 01-12-2013, 08:02 PM   #135
straightsixjeep
I used normal permatex anti seize and it worked great for a solid 2-3 months. Im going down to the garage now to regrease it. Im going to try Chrysler compliant general purpose grease this time.
