Quantcast Greasing the slip joint on 97+ XJ's(Write-up) - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Greasing the slip joint on 97+ XJ's(Write-up)
Old 12-25-2009, 03:25 PM   #91
cricketo99
lol that goes to show you how long it has been since I have logged on. Thanks and happy wheelin'!!
Originally Posted by Jesse
Do you drive a stick?: i would, if sticks had engines
cricketo99 is offline   Reply With Quote
Old 08-02-2010, 06:25 PM   #92
krazy4jeeps
It worked!! I thought it was the rear end. Thanks for posting.
krazy4jeeps is offline   Reply With Quote
Old 08-24-2010, 09:14 PM   #93
Nick7
great write up!
i have a clunk when my zj downshifts from 2-1. do you think this could be the cause? i always thought it was a mount of some sort but it seems this could be the fix?
Nick7 is offline   Reply With Quote
Old 08-24-2010, 09:16 PM   #94
mattathayde
Originally Posted by Nick7 View Post
great write up!
i dont remember hearing anything like that with down shifts, that might be more of just the backlash getting taken back up as the motor tries to rev up
-matt
mattathayde is offline   Reply With Quote
Old 08-24-2010, 09:34 PM   #95
Nick7
its like a loud clunk, i thought that is what this fixes?
Old 08-24-2010, 09:36 PM   #96
johnson989
Did this today in the driveway in about 45 min. No more slamming/jerking just after stopping or accelerating. Great writeup, Thank You
johnson989 is offline   Reply With Quote
Old 08-24-2010, 10:20 PM   #97
mattathayde
its usually upon acceleration or stopping, not down shifting, to the best of my understanding with no grease in it the yoke cannot slide so it pops in and out more than sliding. but backlash is like when you shift into drive and you hear "kunk", which i think would also happen when downshifting since the drive line will end up having the power removed from it as the tranny shifts and then as the motor is speeding up to match the drive line speed force is put back onto the motor from the wheels spinning faster... if that made any sense in type.
idk off hand what your vehicle has since its not an XJ, i know on XJs its a 97+ but idk what versions they use on the ZJs when. if you have a slip yoke theres no hard in greasing it but it might not be what you are feeling
-matt
Old 09-17-2010, 09:18 AM   #98
brigbeach
I have a random clunking while driving not stopping. My son describes it as when your on a wooden roller coaster as your going up the steep hill. It doesn't happen all the time but mainly between 40-55 mph.
Would this fix my problem?
brigbeach is offline   Reply With Quote
Old 09-25-2010, 08:52 PM   #99
CJ2YJ2TJ
My clunk developed after 2 months of owning the XJ. I have had CJs/Wranglers my whole life but had never had a Cherokee and my clunk felt like the transmission was slipping. This thread literally made my year when I realized what I was feeling was in the driveshaft and not the tranny. Jeep is good as new now. Thanks alot
99 TJ - 4.0 - 5 speed - 2" BB - JKS MML & BL & discos - OME's - RE & JKS trackbars - 32" BFG's
99 XJ - 4.0 auto - 30" Yokohama Geolanders
CJ2YJ2TJ is offline   Reply With Quote
Old 11-23-2010, 06:44 PM   #100
firestarter0082
I realize that this is an old thread but it's a great write-up and I think I've ran into the same issue with my 2000 xj.
A few questions since i'm a newb:
1. What causes the slip joint to be loud?
2. If it's slipping across the splines doesn't the lube just cover up the real problem?
Thanks,
firestarter0082 is offline   Reply With Quote
Old 11-23-2010, 06:48 PM   #101
tjwalker
It's the crank sensor!
tjwalker's Avatar
1. Earlier models were lubricated with a bath of ATF fluid in the transfer case.
97 and newer is a re-design. No ATF.
2. It isn't a catastrophic problem, it's more like a nagging design issue that you have to feed/lube once in a while. We have no choice but to lubricate it periodically.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline   Reply With Quote
Old 11-23-2010, 06:59 PM   #102
laredo87
I enjoyed reading your presentation, very well written. I need to ask about the"clunking" in my '87. Is caused by the same lack of lubricants?
laredo87 is offline   Reply With Quote
Old 11-23-2010, 07:55 PM   #103
mattathayde
maybe a lack of lube but yours is lubed from the transfercase/transmission. or it could just be backlash in your drive line or a bad u joint
Thanks,
it makes a sound just because it binds up then finally slips
Old 11-23-2010, 08:26 PM   #104
firestarter0082
Thanks everyone.
@mattathayde: So if the noise is caused by it binding up then slipping doesn't this, basically, mean that the splines are being destroyed over time? And the lube is just there to cover up the noise?
Also, if the splines are being worn down does anyone know how long they last? I started hearing this noise about 2 weeks ago but from reading it doesn't sound like this is an immediate threat to the driveline......
Actually, in thinking about the design how would it bind up since it just slips in and out? I guess I don't mentally see what would be going on here that isn't blatantly destructive.
Old 11-23-2010, 08:43 PM   #105
Sdenzik
1997 XJ Cherokee
I feel so stupid...I was chasing the noise new it was driveshaft related but couldnt put my finger on it.
Great write up.
Sdenzik is offline   Reply With Quote
Glock Forum
