Greasing the slip joint on 97+ XJ's(Write-up)
#76 | ||
if you can take a computer apart you can work on a vehicle, if you slip on a vehicle or break something it usually costs a lot less than you slip on a computer ![]() once you start working on it you will get a lot more comfortable doing it, and things like this are not worth the money to pay a shop to do -matt
#77 |
Well I'm 99.99% sure that this is my problem!
If I cannot get to it for another 2 weeks will I be ok? It only just started to make the noise. |
#78 |
#79 |
I did this just now in my driveway and it took me 1 hour. Im no mechanic either. It helped for one of you guys to tell me it is an 8 mm bolt also. One thing that is most important.....don't forget to chock the wheels! I also used anti-seeze and I think it will be just fine. I also used the old clamps for the boot, by pulling on it with some pliers.
Thanks guys this forum is a great tool and has came to use lots of times I love it..good work!!! |
#80 |
I just stumbled upon this thread and it appears to match the exact problem with my wife's 2001 XJ Limited 4x4.
Only problem is that I can't see the pictures... only the dreaded little red X's. Can somebody please re-post them? I'm going to try to tackle this job this coming weekend. Thanks in advance. More later... Z. |
#81 |
Never mind...
I think it's a firewall issue. I'll try it from home and it should be good to go. Thanks anyway. More later... Z. |
#82 |
I just spent two hours crawling around under my Wrangler, looking for something...ANYTHING that could be causing the clunking sound. It has now gotten to the point where I am actually feeling it through the clutch pedal and the shifter.
I pray this is the cause of my clunking! I will be doing this fix in a day, or so...I'll let you all know if it does the trick. I knew this forum was the place to come for the answer. This place is awesome! |
#83 |
Well, I did the grease thing just now and it didn't do the trick.
Could the front shaft cause a noise/vibration even when in 2WD? The noise and the vibration, which is almost like a shuttering feeling, are only noticible when starting from a complete stop in 1st gear, and sometimes in 2nd (6spd transmission). Any help is greatly appreciated! |
#84 |
RIT Offroaders
Does anybody or cricketo have a copy of the images they could host? this thread is extremely valuable but it seems much less valuable without the pictures
I always refer people over to this thread so if we can get the pics back I'm sure there will be many happy Jeepers
01 WJ Ltd - i6 - QT2 - OME 2.75" Lift - Bilstein 5100s - Dueler AT RHS 255-70-18 (32") - JK Sahara rims - ARB Front Winch Bumper - C4x4 Fab rear tire carrier bumper - Upcountry Skids - Tow Package - KC Dayliters Long Range - Cobra 19 - Boston Acoustics Speakers Build Thread RIT Offroaders Matt |
#85 |
bump! we need those pics again
"I live, I ride, I am.........CHEEP |
#86 |
agreed, i need to do this, where'd the pics go!?
1997 Jeep Cherokee, 4.0L, 30x9.50 Maxxis Bighorns, d-window wheels, cut fenders, chopped bumpers, flex-a-lite, flowmaster super 44 2003 Grand Cherokee Overland, 4.7L HO V8, 6000K HID's - SOLD IT 1996 Grand Cherokee Laredo, 5.2L V8, 3" Kolak exhaust w/ flowmaster 50 and magnaflow cat, K&N FIPK, 4300K HID's - SOLD IT My build thread http://www.myspace.com/HaleyChicoine http://www.facebook.com/home.php#/profile.php?id=1646857227&ref=profile |
#87 |
^ X4. need those pics.
#88 |
pics are still there, copy the image URL and paste it in another window, it will load as long as the request isn't a referral
pics aren't that important though, the write-up basically just says to remove the driveshaft, clean the grease off and liberally apply anti-sieze compound, then reassemble |
#89 | |
Sorry about the pics it has been forever since I have even been on this site. It seems my account became inactive. I think it is fixed now, the pics work for me now anyways. How can I go about making this a sticky? I get a lot of feedback from this post and I think it should go in the FAQ.
#90 |
Drivin' me nuts...
It IS in the Tech/FAQ links and TSBs sticky. Has been for a while.
'99 Classic: "Emma" 8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents Jeeps with Teeth #1 MN Jeeper #14 _____________________________________________ "When is the best time to do things? Who is the most important one? What is the right thing to do?" "BORN TO WHEEL" PRODUCTS FOR SALE **********More designs here********** |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
