Quantcast Greasing the slip joint on 97+ XJ's(Write-up) - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Greasing the slip joint on 97+ XJ's(Write-up)
Old 04-20-2009, 11:00 PM   #61
badlands1
1989 XJ Cherokee
Gonna do this when i get off work.Seems to me like anti seize wouldnt work very well???Isnt that stuff not good when friction and high heat work it..?I dont know anything though just curious.
badlands1 is offline   Reply With Quote
Old 04-21-2009, 01:57 AM   #62
GregB_00XJ
GregB_00XJ's Avatar
I hate the clunk... and now I know the fix!
+10 Props man!!
2000 Jeep Cherokee Classic
1992 M101 CDN2 1/4 Ton Off-road Trailer. 90% Daily Driver 100% Fun!
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline   Reply With Quote
Old 04-21-2009, 07:51 AM   #63
Fox Fader
No problem with anti seize handleing the heat, it's the friction that concerns me that's why I went with the Molylube.
God Rules!
Fox Fader is offline   Reply With Quote
Old 04-21-2009, 08:47 AM   #64
phmaris
I used the valvoline molylube and it lasted two weeks.
So I tried antiseeze and it has been holding up much better.
phmaris is offline   Reply With Quote
Old 04-21-2009, 09:49 AM   #65
XJH-007
I drank what?
XJH-007's Avatar
Seriously?
5 Pages of Replies on Greasing a Slip Yoke?
Is this what JF is coming too?
Keep an eye out for my Tech sticky on "How to Air Up your Tires at a Full Service Gas Station"
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline   Reply With Quote
Old 04-21-2009, 08:55 PM   #66
Fox Fader
Originally Posted by XJH-007 View Post
Seriously?
... and?? everyone dosen't know about this fix.
God Rules!
Old 05-05-2009, 11:41 AM   #67
98_XJ
Can this be done easily without power tools and what is the verdict on what kind of grease to use? Is anyone for sure that the driveshaft is not balanced from the factory and are there only four bolts that hold the driveshaft in place?
1998 Jeep XJ Limited 4x4
- Rough Country Series II 3" Lift
- 31-10.50-15 Duratracs on Black Rocks
- JCR Offroad Stage 3 Front Bumper
2010 Chevy Equinox
98_XJ is offline   Reply With Quote
Old 05-05-2009, 06:15 PM   #68
mattathayde
hand tools, just need a big hammer and maybe a heavy friend.
just mark the ds with chalk when you pull it to be safe. and yes just 4 bolts but the u joint might want to stay put so that where a hammer and pb blaster come in
-matt
mattathayde is offline   Reply With Quote
Old 05-09-2009, 11:50 AM   #69
98_XJ
Thanks to the original poster the fix worked great and was very easy. You only need hand tools and the driveshaft is light. Here are some tips to make it go smoothly.
1. Use the anti seize which was originally recommended.
2. Spray "Blaster - Penetrating Catalyst" (Autozone) on the four bolts and u joint the night before.
3. Respray bolts and u joint before you start.
4. Only remove one clamp (2nd) by sliding a flat screwdriver between the connector and clamp and twist.
4. Once the four bolts are removed, lightly tap with hammer both u joints and spray another shot of Blaster on the u-joint again.
5. Slide driveshaft toward engine and it should come right off with no muscle at all.
This literally took no more than 1 hour taking my time. Once again great fix!
2010 Chevy Equinox
Old 05-17-2009, 11:58 PM   #70
Fox Fader
Moly lube still holding fine for me after almost 1.5k miles.
God Rules!
Old 05-18-2009, 07:30 AM   #71
conrasm
The yoke straps are 8 mm bolts.
I use anti seize all the time on my heep. I have found that if you cut it with about half wheel bearing grease, it won't dry out as easily.
My dad tried using never seize, which is a similar product as the anti sieze, just for industrial applications, in a A/C fan bearing and it only lasted for a few days. All the grease mixed with the powerdered nickel dries up under high heat conditions.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
Heritage Region Jeep Alliance
conrasm is offline   Reply With Quote
Old 05-18-2009, 08:02 AM   #72
nujeepguy
1997 XJ Cherokee
antiseize usually will dry up or at least gum up. i only got 4 months with anti-seize and so far 1 year 6 months with lucas wheel bearing grease. green stuff.
nujeepguy is offline   Reply With Quote
Old 06-28-2009, 08:33 PM   #73
compcrasher86
RIT Offroaders
compcrasher86's Avatar
just did it with valvoline heavy duty wheel bearing grease and WOW. Thanks OP that was a useful tutorial. Anybody else other than me entertained by the "PLOOOP" when you pull the driveshaft out of the rubber boot? hahahahah
01 WJ Ltd - i6 - QT2 - OME 2.75" Lift - Bilstein 5100s - Dueler AT RHS 255-70-18 (32") - JK Sahara rims - ARB Front Winch Bumper - C4x4 Fab rear tire carrier bumper - Upcountry Skids - Tow Package - KC Dayliters Long Range - Cobra 19 - Boston Acoustics Speakers
Build Thread
RIT Offroaders
Matt
compcrasher86 is offline   Reply With Quote
Old 07-04-2009, 10:46 PM   #74
jbarr2000
1997 XJ Cherokee
I work for a fertilizer company and we use silver grade anti sieze all the time. We have been told by a few people not to use it on moving parts like splines and such because it will cause wear. The stuff we use has little bits of metal in it apparently, so be careful what you stick in there.
jbarr2000 is offline   Reply With Quote
Old 08-10-2009, 12:36 AM   #75
gigatigga
2005 WK
i have this exact issue with my 98 i just bought. one question, it doesn't really bother me, and i'm kind of a wuss about taking crap apart (i'm a computer tech, not an auto tech). Am i going to ruin anything if i just leave it? If i wanted to pay a shop to do this, would i just ask them to grease the slip yoke?
Thanks for your responses.
gigatigga is offline   Reply With Quote
Glock Forum
