Quantcast Greasing the slip joint on 97+ XJ's(Write-up) - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Greasing the slip joint on 97+ XJ's(Write-up)
Old 04-08-2008, 08:13 PM   #46
itasor
2009 JK Wrangler
Originally Posted by Timberwood View Post
So what is the right grease for this? Can you use the same stuff that goes in the steering zerks?
You probably could but it'll just wear off in a week I think. Most people use anti-seize, yet some say you should use special nickel plated driveshaft grease.
Anti-seize really shouldn't hurt anything though and there are way too many people that do theirs using it that it can't be an issue.
itasor is offline   Reply With Quote
Old 04-11-2008, 11:55 AM   #47
Timberwood
Im going to do this today. Ive got CV joint grease, that should be good right? Ive seen that anti-seize really isnt for high temp or friction areas
Timberwood is offline   Reply With Quote
Old 04-11-2008, 12:04 PM   #48
trsroller
great write up, i need to do this on my jeep i have been wondering what the noise was on my jeep when braking, i have been waiting for the snow to melt to crawl under and take a look around. Now i dont even have to. thanks!
trsroller is offline   Reply With Quote
Old 06-06-2008, 04:21 PM   #49
ksander
Does anyone else advise using some locktite so the bolts don't come loose?
ksander is offline   Reply With Quote
Old 07-19-2008, 01:12 PM   #50
mattathayde
great write up, just did this with my father and the instructions were right on.
thanks
-matt
mattathayde is offline   Reply With Quote
Old 08-25-2008, 07:04 PM   #51
4SEVEN3
Bump!!
I was searching for a different issue and came across this thread! Excellent write-up, thanks for taking the time!
Ive got this clunking going on like the rest of you guys and Im gonna give it a shot this week sometime. I may throw in some Ujoints for good measure...definitly couldnt hurt!
Thanks Again!!!
4SEVEN3 is offline   Reply With Quote
Old 08-25-2008, 07:23 PM   #52
mattathayde
ya, it will help with the clunk but the whole adage here of needing a hammer to get the u joints out is no joke (i have a 01 with 78k on it and i had to give it a lot of wacks)
i got some other issues going on that gave me a clunk still that an italian tune up fixed for the most part.
-matt
Old 09-15-2008, 09:57 AM   #53
shouston75
Did this last night. No more annoying clunk.
shouston75 is offline   Reply With Quote
Old 09-15-2008, 01:27 PM   #54
MXdude105
Occasionally when i come to a stop, there is a loud clunk and the brake pedal gets really stiff for a split second, almost feels like it is rebounding back at me....is this the clunk that you guys are describing?
-2000 XJ Cherokee Sport 4x4. 4.0L, NP231, c8.25, aw4, RC 3" AAL........SOLD
-1995 Mustang GT 302
MXdude105 is offline   Reply With Quote
Old 09-15-2008, 01:48 PM   #55
mattathayde
not so much the added symptoms, at least i never noticed the breaking issue. check your u bolts that hold in the back axel. you may have a combo of things causing it. if you havent ever greased the SY or it hasnt been done for 2 years do it, its not to hard and should be done semi often (2 years or so unless you put a lot of miles on it then do it more often). i would also suggest if you dont do much highway driving to grease the yoke, check the u bolts on the axels, and then run it on a good long highway drive and see if that clears it up.
-matt
Old 10-20-2008, 11:40 PM   #56
Redbob
Originally Posted by tdogg55555 View Post
Nice write up, So what about the zerk fitting on the slip joint? Ive tried putting grease through there, I still get the clunking upon acceleration though.
Most slip-splines will vent the grease out before it really gets into the splines.
Take it apart, or almost apart, wipe the swarf out of it, and grease it with your favorite flavor of heavy grease.
This will work on anything from Jeeps to Broncos, to pickups trucks, vans, etc. - they all do the clunk, and this will fix it.
Redbob is offline   Reply With Quote
Old 04-19-2009, 11:01 PM   #57
Fox Fader
My Bronco did this 9 years ago and i never could figure it out. I'll be doing this to the XJ in the morning. Finally found this! Found the same info in another forum too. http://forums.off-road.com/jeep-mid-sized/8425-clunk.html
I'm hung on moly grease or anti-sieze.
I guess my brake vibration (after rotors and drums) is another problem.
God Rules!
Fox Fader is offline   Reply With Quote
Old 04-20-2009, 07:11 AM   #58
FG Jeep
GM makes a special grease for this. Its called molylube if i remember right. GM had this same problem with mid 90's tahoes, suburbans, and pickups. It works pretty well and it isn't to expensive and a can of it will probably last you 10 years if its for you vehicle only. We do it ever three oil changes on my brothers tahoe. Because pulling the driveshaft on that truck is a five minute job.
1998 XJ Sport
1998 ZJ 5.9 Limited for sale see my link on jeep forum.
http://www.jeepforum.com/forum/f153/1998-jeep-grand-cherokee-5-9-limited-1286243/
FG Jeep is offline   Reply With Quote
Old 04-20-2009, 07:48 AM   #59
Fox Fader
That's funny, my buddy who has been a mechanic for 25 years, looked at mine and said it's no big deal, knew that the GM trucks had this problem too, but didn't know there was a maintenance fix.
God Rules!
Old 04-20-2009, 07:11 PM   #60
Fox Fader
I used the Molylube Valvoline blend.
This works like a charm, I'm so glad I found this info cause that thump was reeeeeeaallly starting to bother me.
thanks!!
God Rules!
Glock Forum
