Greasing the slip joint on 97+ XJ's(Write-up)
#31 | |
know what one of my first projects will be if all works out
#32 | ||
Here a link from advance: http://www.partsamerica.com/ProductDetail.aspx?MfrCode=DOR&MfrPartNumber=03635 &CategoryCode=3530 All the tools needed are a pair of pliers pretty much, maybe a screwdriver. |
#33 | |
#34 | ||
torque em till theyre tight enough.
White 96 XJ Sport Jeepforum Minister of Sarcasim 4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.White Jeep Club Member #911 Code 3 Jeep Club Member #1 Eagle Scout Jeep Club Member #2 Quote:
#35 |
My '97 FSM says 14 ft-lbs. I know mine were a bit tighter than that. Just be careful not to snap them. Also some locktite wouldn't hurt either cuz that would suck if they came loose. I also reused my old straps and bolts. Probably not suppossed to, but mine were in good shape.
#36 | |
#37 |
Thanks!
Thanks for this writeup! I just purchased my first jeep last week which is a 1998 XJ and I was going a little gray over the weird movement at starts and stops. I am going to give this a try tomorrow.
#38 |
Finished the job about a hour ago and it did the trick. I went slow though the steps and it took me about an hour. What a great write-up!!!
#39 |
When you zip tie or clamp the boot back onto the driveshaft, is there a certain position the boot should be in? Meaning, should it be scrunched up a little, or just let it go how it wants and then zip tie it/clamp it?
Or doesn't it matter? ![]() |
#40 |
thank you so much ive been wondering why my 98 xj clanks on stop and go!
#41 | ||
LOL I remember this thread. I tried using spray lithium grease, and it did not help much. Make sure you use the the right lube for the task.
#42 |
just so nobody over-tightens them, the bolts on the straps need to be tightened to 14 ft. Ibs.
#43 |
just did this and it worked! took me about thirty minutes. thanks again!
#44 |
My shop manual says to tighten those straps to 14 ft. Ibs.
#45 |
So what is the right grease for this? Can you use the same stuff that goes in the steering zerks?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
