Greasing the slip joint on 97+ XJ's(Write-up)
| 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full | Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
This is my first write up so bear with me. I could never find a write up for greasing the slip joint for 97+ XJ’s that causes the clunk on braking right before a stop and also a clunk on initial acceleration. So I decided when I did mine I would take some pics(not sure how to make click free,sorry). So here goes.
Tools needed: -New CV clamp (see pic below) -Anti-seize (used as a replacement for grease; saw it on another thread somewhere) -Ratchet and socket for U-joint straps(can’t remember off the top of my head what size) -Hammer -Spray paint -About 45 min. Here is pics of the clamp and anti-seize: ![]() Sorry for the blurry pic ![]() First start off by marking your driveshaft with paint to ensure that it gets reinstalled the way it came out as to not knock off the balance of the driveshaft. ![]() Really all you need to mark is where the shaft and pinion meet. I kept the wheels on the ground and put the trans in park to insure that the output shaft of the xfer case would stay the same. Now you can cut the clamp off the boot or use a screwdriver or something. It is the one on the right: ![]() Then go about removing the four bolts on the U-joint straps. Those right there, there are 2 on each side: ![]() After the removal of the straps push the driveshaft towards the xfer case to get enough clearance for the U-joint to clear the pinion. It may take a little effort to break free the U-joint. I had to tap it with a hammer to get it to. Be careful with the caps on the U-joint, mine fell off a few times so you could put tape on them to hold them on. Now just pull out the driveshaft. Now lock down the shaft so you can deal with the female end without it moving all about. I put mine in a vise. As you can see there was very little grease left: ![]() I took a rag and cleaned out any grease left in there. Then you can start applying the anti-seize. I applied it pretty liberally but you probably don’t need that much. Now get up under the Jeep and put some also on the output shaft. This also had very little grease: ![]() I figure more is better than not enough. ![]() ![]() Now you are ready for reassembly. Push the slip joint together making sure to line up the paint. Now back it off until it seats with the pinion; basically the reverse of disassembly. Bolt the straps on and then move back to the boot that we have to clamp back on. I used a universal clamp that needed no tools since I had no CV clamp tools. If you have the tools it probably will be a little easier since these clamps are a little hard to work with. After much avail however I got mine on nice and tight. Like I said this only took me 45 min. and I was taking my time. After that you are done and hopefully your problem is solved. I have been running like this for a few months with no clunking but I read somewhere that his has lasted something like 6 years so I guess time will tell. If I left anything out please feel free to comment. As I said this is my first write up.
#2 | |
Little Red Menace
Nice write up.
93 Sport Beer is proof that God loves us and wants us to be happy............Ben Franklin Specs in Profile. http://www.cardomain.com/ride/325707/1 http://www.cardomain.com/ride/2406854/1 |
#3 |
nom nom nom
You may have just saved a lot of driveshafts from a premature demise. A lot of folks aren't even aware that they should lube thier slip-joints.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount '97 Cherokee Sport 5spd,231, white, stock '90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc. '87 XJ 2" lift '96 XJ stock "Personally, I've learned so much from my mistakes, I'm thinking of making some more." "Don't believe everything you think..." |
#4 |
Good write up. That may qualify for a free membership.
1982 Jeep Scrambler 5.3 Vortec SOA on 37s |
#5 |
Nice write up, So what about the zerk fitting on the slip joint? Ive tried putting grease through there, I still get the clunking upon acceleration though.
96 Country...Weekend warrior |
#6 |
Is anti seize the best choice for that? Good write up regardless.
"Let the divine arguments of existance drive us to starvation until all of our knowledge is exhausted into the very existance we have denied ourselves." -Sean J Godfrey |
#7 | |
nom nom nom
Earlier models were lubricated with atf from the t-case.
#8 | |
#9 |
nice write up...i have to remeber to do this to the stock one
2000 RED XJ 4.5" RE Super Flex, Mono Tubes, 31" BFG AT, WJ seats Front and rear, Boxed Rocker panels with Rails, Upcountry Junkyard Special, homemade front bumper, C4x4 rear bumper and swing out, low profile light bar, jks disconects, farmboy tail lights lebaron hood vents, teraflex sye, Dana 30 HP with factory 4.56 disco converted to solid shafts, with powertrax, Dana 44 with detriot true trac with 4.56 and ZJ disc brakes...and the best part is all of my major mods are used Ebay items |
#10 |
Yea I was surprised when I couldn't find a write-up on it considering every Cherokee I have ridden in 97+ have had the clunking.
#11 |
thats pretty wierd, i just did mine today befor you posted the write up...since its 60 degrees out in january i figured why not go out and work on the jeep. The clunk when i stop is pretty much gone and it just seems to drive smoother and quiter for some reason. i didnt bother with getting new clamps though, the one on the TC end just slid off and back on. On the DS end i just used a zip tie.
'97 XJ (here comes the typical list) 3" rustys full pack, Rock Krawler tracbar, 31x10.5 Kumho kl71, CIK, dynomax super turbo muffler, IPF h4 conversions, silverstar bulbs, hella 530 fogs, olympic 4x4 rock front bumper, tcase drop, bush hacker flares, OEM tow hook brackets with GM hooks |
#12 |
Nice write up.
[B]A couple of XJ's with blah, blah, blah...[/B] |
#13 |
I clean mine about every 3 years...I leave the metal CV strap and boot on the output shaft of the TC and clean the inside of the boot and shaft with brake cleaner and a rag... then I use a thick zip tie for the back end of the boot when I put it back on.. a lot cheaper and a lot easier.... I personally like wheel bearing grease..... every 6 months I just snip the zip tie and shoot some grease in through the back end of the boot with a grease gun.. that is why I can get 3 years without having to rip it apart for cleaning.
1993 XJ Sport RIP (Parts) - 189k, white, 4.0, automatic, command-trac NP231 1996 XJ Sport Daily Driver - 95k, stone white, 4.0, automatic, selec-trac NP242, Tow Hooks, SRB fog lights, tinted glass. 2005 Wrangler Rubicon Summer Toy - 8k, 100% STOCK...silver, automatic, soft and hard tops and doors My Pics "life moves pretty fast... if you don't stop and look around once and awhile, you could miss it"...F. Bueller |
#14 | ||
So this dosent need to be done on the pre 97s?
White 96 XJ Sport Jeepforum Minister of Sarcasim 4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.White Jeep Club Member #911 Code 3 Jeep Club Member #1 Eagle Scout Jeep Club Member #2 Quote:
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
