Grand Cherokee Front Axles Shafts - JeepForum.com
post #1 of 9 Old 09-22-2012, 07:56 AM Thread Starter
Nick1981
I recently went to a self service junk yard looking for front axle shafts and there were only 3 XJ's with good axles. I stopped and looked at a few Grand Cherokee's and the axles look like they will work. Does anyone know if they will work and what years are the same?
1998 XJ Unlocked Unported Unpolished
Nick1981 is offline
post #2 of 9 Old 09-22-2012, 09:22 AM
jeepjunkymike
dana 30 is a dana 30 no matter what yr,,as long as its not the disconnect pass split shaft,,,yes they are all interchangeable. withe exception of abs tone rings,,if yours has abs then you will want the ones with the tone rings
lift it,,,,fat girls cant jump
jeepjunkymike is offline
post #3 of 9 Old 09-22-2012, 05:26 PM Thread Starter
Nick1981
What about the tie rod and drag link? It looks like i could swap out the passenger side steering knuckle and use the steering parts off of the grand Cherokee on my xj. Would that work?
Nick1981 is offline
post #4 of 9 Old 09-22-2012, 05:34 PM
whitexj98
Not completey, The WJs 99up are wider, making everything different. And earlier are low pinion with CV shafts.
Im gussing your looking at a WJ axle? Short answer, no you cant just swap it on. The knuckels can be made to work but the linkage wont work due to the WJ being wider. Searh WJ knuckle swap.
98 XJ lifted/Locked/Geared
My Build: http://www.jeepforum.com/forum/f177/my-98-build-1253511/
whitexj98 is offline
post #5 of 9 Old 09-23-2012, 02:10 PM
jeepjunkymike
thought we are talking xj and zj because they use a dana 30..,,somebody plz correct me if im wrong,,
post #6 of 9 Old 09-23-2012, 02:49 PM
whitexj98
And so do WJs...but like I said they are not the same as eariler dana 30s...
post #7 of 9 Old 09-23-2012, 06:10 PM Thread Starter
Nick1981
[QUOTE=whitexj98;14203737]Not completey, The WJs 99up are wider, making everything different. And earlier are low pinion with CV shafts.
So the axles will work 98 and earlier? Are all of them CV's?
Nick1981 is offline
post #8 of 9 Old 09-23-2012, 07:52 PM
jeepjunkymike
some were u-joint,,,and the tie rods and all the drag link and what not will work from a zj and are stronger
post #9 of 9 Old 09-23-2012, 07:55 PM
jeepjunkymike
just for the record,,,what i said in the first place,,,,yes,,all the grand zj stuff is bolt on for your xj,,,,
can we use grand cherokee front end? damage inc. XJ Cherokee Technical Forum 2 09-28-2010 03:24 PM
Grand cherokee front clip on a cherokee sport hockeyman590 XJ Cherokee Technical Forum 1 07-14-2010 02:42 AM
grand cherokee axles under cherokee XJ90 XJ Cherokee Technical Forum 3 10-21-2008 09:35 PM
is there a difference between grand Cherokee and Cherokee axles? 510z XJ Cherokee Technical Forum 13 05-31-2008 05:48 PM
Front D44 out of grand cherokee?? rosader XJ Cherokee Technical Forum 10 01-04-2008 06:14 PM
