Quantcast Grade 5 Bolts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Grade 5 Bolts
GR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!
Old 04-13-2007, 05:09 PM   #1
younghunter
Grade 5 Bolts
Are grade 5 bolts strong enough for the leaf springs and lower control arms. I can't find grade 8 bolts that will work anywhere.
younghunter is offline   Reply With Quote
Old 04-13-2007, 05:18 PM   #2
joey-nac
1993 XJ Cherokee
Have you looked at a AutoZone or Pep Boys? They both have Grade 8 bolts. Hardware stores should too.
1993 2 door XJ Sport 4.0
5" DPG Coils with 3/4" spacer
4.5" Rough Country Leafs with 1" TNT boomerang lift shackle.
TNT Longarms with Bellypan
TNT Frame Rail Stiffenerz
DPG Gas Tank Skid
D30 Aussie locked with Yukon chromollys shafts 4.88s
D44 33 spline detroit with Moser chromollys shafts 4.88s
Teraflex SYE with Tom Woods custom DS
36x13.50 Iroks on 15x10 Pro Comp Rock Crawlers with Custom beadlocks.
joey-nac is offline   Reply With Quote
Old 04-13-2007, 05:25 PM   #3
Schmeidler
lowes and home depote normally carry them. If not look in the yellow pages under fasteners
Schmeidler is offline   Reply With Quote
Old 04-13-2007, 05:34 PM   #4
younghunter
the size I need is 9/16, the only place that has them is fastenal but they have to special order them. The hardware store has grade 5 in the size i need. Everywhere I gol tells me its an odball size. Wanted to install my lift this weekend and waited till the last minute to get new bolts.
Old 04-14-2007, 01:10 AM   #5
Mike94ZLT1
No way, not worth the risk.
2009 Jeep Grand Cherokee Laredo 4.7, 4WD, Stock for now
2006 Ford E-150 4.6, RWD, "The Happy Bus"
2003 Jeep Grand Cherokee Laredo 4.0, 4WD, Stock for now
1999 Corvette FRC 383 LS6 stroker, build drivetrain, full suspension, not much left that's stock
1937 Ford 5 Window Coupe 327 SBC, M-22 4 speed, etc..
Mike94ZLT1 is offline   Reply With Quote
Old 04-14-2007, 01:30 AM   #6
BrunoS
go to machine shop, look in yellow pages.
Grade 5 bolts are very good, don't know about grade 8 bolts.
rule of thumb:
grade 5 will bend before breaking
grade 8 is very tough, but brittle, and won't bend as much before breaking. but much stronger.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline   Reply With Quote
Old 04-14-2007, 02:05 AM   #7
88_xj_hunter
1988 XJ Cherokee
X2 don't chance it. As Bruno said, grade 5 wiil stretch more as opposed to grade 8. On the leaf springs that could spell disaster.
'89 XJ Laredo 4.0L, AW4, NP242, Dana 30, 35 w/Lock Right, 5.5" lift, 35x12.50x15 Uniroyal m/t
'88 XJ 4.0L, AW4, NP231, Dana 30, 35 w/Lock Right, 4.5" lift, 31x9.50 SuperSwamper on salvaged 15x7's
'87 XJ Pioneer 4.0L, AW4, NP231, Dana 30, 35 w/ trac-loc, currently stock, 8" lift one piece at a time
[QUOTE=mdonohu1]i sweat your nuts. badly.[/QUOTE]
88_xj_hunter is offline   Reply With Quote
Old 04-14-2007, 02:41 AM   #8
cdn_xj
I've returned to the fold
cdn_xj's Avatar
1995 XJ Cherokee
Use Grade 8 with a National Fine (NF) thread. You could use National Coarse (NC) but it is easier to set the torque with fine thread bolts.
cdn_xj is offline   Reply With Quote
Old 04-14-2007, 10:44 AM   #9
TheNerd
There is always http://mcmaster.com
-2001 XJ Limited, 4.0L, NP231 w/ SYE, AW4, 4.5" Lift, 32" tires, 4.56's
-1987 XJ Pioneer, 4.0L, NP231 w/ SYE, NV3550, 4.5" lift, 4.10's, D44 rear
TheNerd is offline   Reply With Quote
Old 04-14-2007, 11:20 AM   #10
joey-nac
1993 XJ Cherokee
Correct me if I'm wrong but isnt 9/16ths the same as 14mm?
DPG Gas Tank Skid
Old 04-14-2007, 11:31 AM   #11
Timo_90xj
Timo_90xj's Avatar
1990 XJ Cherokee
If you're talking about the front leaf spring mounts (or shackle bolts or LCA bolts for that matter), they are NOT 9/16"!!
All leaf spring bolts, as well as LCA and UCA bolts, and track bar bolts are METRIC. 9/16" is very close to that (slightly larger in diameter), but the thread pitch is totally different. So unless you want to ruin the weldnuts inside the unibody frame rail, get metric bolts.
14mm x 110mm and 2mm thread pitch is the correct size for LCA and leaf spring bolts. Class 10.9 is the metric equivalent of grade 8.
edit: and get those class 10.9 or grade 8 bolts. I used class 8.8 bolts (around the same as grade 6) on mine for a while, can't say they took the beating too well. I've actually bent a class 8.8, 10mm bolt on my downhill bike which attached the rear shock to the frame... those lower class/ grade bolts are not meant for something like that. Those stronger bolts are there for a reason.
1998 Grand Cherokee 5.9 LX, 100k miles, 1.75" BB, 32 x 11.50 BFG MT KM2s, custom- fabbed bumpers etc..
http://www.jeepforum.com/forum/f13/daily-driver-5-9-build-thread-bumpers-tube-rockers-etc-1222317/
***Under construction***
1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear, etc...
http://www.jeepforum.com/forum/f11/hybrid-cage-build-exo-cage-internal-973910/
Timo_90xj is online now   Reply With Quote
Old 04-14-2007, 01:28 PM   #12
JrTjK
1982 J-Series Truck
check out www.boltdepot.com
JrTjK is offline   Reply With Quote
Glock Forum
