Quantcast Got some ?'s (wheel fell of on highway) - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Got some ?'s (wheel fell of on highway)
Old 01-01-2007, 10:01 AM   #16
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
Originally Posted by EricsXJ
You don't have a full-size spare?
If you do, use that or get a new wheel. Then if you still have vibrations or problems with the brakes, I'd probably start looking for a new (and better) axle rather than try and repair a junk D35.
YOu must not have read the club in my sig,
I think i will start to look for a 8.8 with discs and 4.10's anyway, even if its not messed up. Ill have to go re-read the axle swap section of your book, im sure it will tell me everything i need to know
Arcticcat843 is offline   Reply With Quote
Old 01-01-2007, 10:06 AM   #17
Arcticcat843
dakuda is a god
1980 CJ5
Originally Posted by Jeepwheeler2
Proper torque is 85-115 ft. lbs.
I would at least put on a new wheel and drum, and would pull out the axleshaft and install 5 new lug studs and all new nuts. I'm sure you can pick up a used axleshaft for next to nothing if your unsure if it is bent. Also, check all your other wheels for looseness, cracked lug studs now, before you loose another wheel.
I did check all the rest, I was thinking maybe i should put on longer stud, becuase my wheel are thicker than stock, what would be a good size?
Old 01-01-2007, 10:09 AM   #18
Arcticcat843
dakuda is a god
1980 CJ5
Originally Posted by TopThrillJoe
.... trust me hes exagerating
What are you talking about, go away,
every time i take a wheel off i ALWAYS use a big rachet with a pipe over it and tighted them as much as i can, well at least to the point were i think they are going to strip
I think i am going to block you becuase i am really sick of you messing up my threads
Old 01-01-2007, 11:02 AM   #19
mortalenema
Drivin' me nuts...
mortalenema's Avatar
Buy a torque wrench and start using it right away.
When I was in high school I had the front tire fall/fly off my Comanche twice in one night. Since then I have always carried a torque wrench in my Jeeps, and checked the torque every time I got out for days after a tire removal. It's unbelievable how loose those things get on aluminum rims after 40 or 50 miles.
I bet your axel is just fine, but a new drum and new/longer studs are a must.
Check the lug holes on your wheels. If they are chewed up you need to get them repaired or they'll work loose again.
mortalenema is offline   Reply With Quote
Old 01-01-2007, 11:14 AM   #20
Arcticcat843
dakuda is a god
1980 CJ5
How long of studs?
The wheels are chewed up but on the inside of the holes, not the outside were the lugs go.
Old 01-01-2007, 11:19 AM   #21
Jeepwheeler2
You want at a minimum of 3/4" of thread sticking out of your wheel for the nut to thread onto. Measure how much thicker the new wheels are, then go down to the parts store with the old studs and match up some longer ones. Also, as stated by someone else, make sure you are using the correct lugnuts with those wheels.
'96 XJ 4.0 AW4, 3" Homebrew lift, homebuilt tree felling bumper, warn x-case skid, roof mounted spare and hi-lift, lots of custom bent sheetmetal.
Jeepwheeler2 is offline   Reply With Quote
Old 01-01-2007, 11:58 AM   #22
mortalenema
Drivin' me nuts...
Originally Posted by Arcticcat843
How long of studs?
Are the holes still smooth and round?
If there is too much play between the the lug and the walls of the hole, it will be that much easier for the wheel to work loose again.
Old 01-01-2007, 12:01 PM   #23
Jeds Sr.
I can't believe you posted this I thought WHICH ONE OF YOU DIRT BAGS SAW ME ON THE SIDE OF THE ROAD?? Same crap happened to me Saturday night on the way home from wheeling. Well in my case it was the front tire not the rear. It's a long story but we were on the side of the road for about ......2 minutes and the cops came up and set behind us till we got the tire on so when we pulled out we had blue lights in our eyes The good thing about the cop behind us is the move over law. Most (not all) cars moved over to the other lane.. Un-nerving man!!!! I know how you feel.
as for damage, don't know, not looking till next weekend. I don't want to fool with it
as for the cause, no dought I need to check out my impact wrench.
Jeds Sr. is offline   Reply With Quote
Old 01-01-2007, 03:10 PM   #24
Arcticcat843
dakuda is a god
1980 CJ5
Wow that sucks, i bet the rear tire falling off is alot better than the front, no cops stoped to help us
Old 01-01-2007, 03:12 PM   #25
Arcticcat843
dakuda is a god
1980 CJ5
They are still round on the outside of the rim but they are tore up on the inside
Glock Forum
