going on a trip - JeepForum.com
post #1 of 19 Old 07-14-2013, 03:38 PM Thread Starter
PurpleToxin1
going on a trip
Alright, I recently got nt jeep and on the 26th ill be taking her on a trip about 700 miles(round trip). What should I check/replace? I know the basics, like tires, oil, fluids, ect. What should I take with me, ill have about 300-350 to do any work or buy anything. The only issue ive had was it like stuuters when leaving in the morning but a tap of the gas makes it go away. Should I have mechanic do the work?
PurpleToxin1 is offline
post #2 of 19 Old 07-15-2013, 09:16 AM Thread Starter
PurpleToxin1
Help bump
post #3 of 19 Old 07-15-2013, 01:47 PM
jeepkid03
Winning
jeepkid03's Avatar
Do a coolant flush and make sure your cooling system is in good shape before going on a long trip.
-Josh
My 0331 Head Swap How-To Thread:
Build Thread:
jeepkid03 is offline
post #4 of 19 Old 07-15-2013, 02:47 PM
Floreancig_XJ
Seems like you got it down, all fluids. Bring a spare tire, wrenches, jack.. Change oil if need be.. Check coolant jf its been a couple years change it( flushings up to you but reccomended..) check rad hoses.. Maybe some fresh coppers if there old might as well get the best mileage u can.. Other than that i trust my 4.0 across the country!
Floreancig_XJ is offline
post #5 of 19 Old 07-15-2013, 02:52 PM
Floreancig_XJ
Also i have the same stutter issue.. Only off a fresh crank.. Changed plugs wires cap rotors cleaned tb and iac.. No luck yet
post #6 of 19 Old 07-15-2013, 02:57 PM Thread Starter
PurpleToxin1
Do you think it's a valve?
post #7 of 19 Old 07-15-2013, 04:01 PM
Floreancig_XJ
It knocks a bit when it does it, im pretty much mechanically inclined with everything but motors.. Ill be testing my tps next but i only have one electronic voltage meter.. Apparently you need an analog one
post #8 of 19 Old 07-15-2013, 07:11 PM Thread Starter
PurpleToxin1
Kinda sounds like a small back fire, lol I used to make my jetta do them on purpose, I don't think I want my jeep to
post #9 of 19 Old 07-15-2013, 07:51 PM
Floreancig_XJ
Yeah if i start it and take off for instance , turn and merge and it bogs.. Dangerous stuff lol
No engine codes either
post #10 of 19 Old 07-15-2013, 07:57 PM Thread Starter
PurpleToxin1
So far ive read it could be manifold crack or leak, ignition, or fuel delivery. Thinking of putting 5.0 injectors
post #11 of 19 Old 07-15-2013, 08:14 PM
Floreancig_XJ
My exhaust manifold is definetly leaking, not sure if its cracked or the gaskets gone, ill let you know if my problem persists after. Hopefully
Its not cracked!
post #12 of 19 Old 07-15-2013, 10:16 PM Thread Starter
PurpleToxin1
Yeah ley me know, ill be going on a trip soon, and would like to fix before then
post #13 of 19 Old 07-16-2013, 05:49 AM
Floreancig_XJ
I believe on friday ill have sometime to check it out
post #14 of 19 Old 07-16-2013, 08:17 AM Thread Starter
PurpleToxin1
i leave next friday
post #15 of 19 Old 07-17-2013, 10:09 AM
jeepkid03
Winning
jeepkid03's Avatar
The cracked exhaust manifold is very common on the 4.0L before 2000 and makes a ticking sound that quiets a bit after the engine is warmed up.
-Josh
Build Thread:
