Going to the JY for an 8.8 - Page 6 - JeepForum.com
post #76 of 84 Old 07-06-2013, 12:50 AM
Mike934
Ford areostar or any ranger should work for ya. Mines out of the junkyard from a ranger, my spares off a areostar. Or the other way around..the areostars on their and the rangers a spare.
I also have some rancho adjustables and some. Pro comp mx6s for sale. Pro comps were nicer, just too long for me.
Overlanders do it over land via overlanding because they like to overland?
Mike934 is offline
post #77 of 84 Old 07-06-2013, 01:23 PM Thread Starter
AM92
1992 XJ Cherokee
I picked one off an aerostar and it worked out fine! I still have to go back to one of the shops they welded the shock mounts upside down. :/
AM92 is offline
post #78 of 84 Old 07-06-2013, 01:24 PM Thread Starter
AM92
1992 XJ Cherokee
gave the 8.8 a test try and yea the lsd works good haha
AM92 is offline
post #79 of 84 Old 07-06-2013, 01:24 PM
Mike934
Its always something huh?
Mike934 is offline
post #80 of 84 Old 07-08-2013, 09:03 PM Thread Starter
AM92
1992 XJ Cherokee
Can anyone one tell me what are some cheap rims / wheels combo
AM92 is offline
post #81 of 84 Old 07-08-2013, 09:39 PM
Mike934
I'm rolling stock 15x7 "sawblades". And 2" spacers up front to clear my wj swap & 1.25 or 1.5" spacers rear. If you run stock wheels you need a 7/8" spacer to clear the calipers...or else they'll rub em.
Personally the dwindows I had were. HEAVY. I wanted steelies though.. I always liked the sawblade steelies. So I did them with spacers. I vote against aluminum wheels cause if you smash one, they will cracked or shatter. A steel one will bend. And mostly likely can be bent back with a hammer or rock to get it drive able at least.
Mike934 is offline
post #82 of 84 Old 07-08-2013, 10:04 PM Thread Starter
AM92
1992 XJ Cherokee
I recently bought 31s bfg a/t for my truck last september which has 16" rims although they are 6 lug.. what would I need to do to make it work? I was planning 35s but my 31s could see alot of life left their only 80% tread ,I never really like aluminum but instead of buying new tires I could get some decent rims especially now sinec im running 4:56s
AM92 is offline
post #83 of 84 Old 07-09-2013, 01:49 AM
Mike934
You'd have to buy 16s in 5x4.5 pattern...or adapters.... Honestly I wouldn't run 16s...on 35s I "may" bump up. To 17s because all the desert race trucks run 35/17s...so their new or lightly used tires are cheap and easy to come buy.. But only for that reason.
I'm o 33s and will be forever so 15s is what I'm running.
Mike934 is offline
post #84 of 84 Old 08-17-2013, 07:43 PM Thread Starter
AM92
1992 XJ Cherokee
I'm thinking about running 16" rims on 35a
AM92 is offline
8.8 , hpd30 , jeep , np231 , xj
