Going to the JY for an 8.8 - Page 2 - JeepForum.com
post #16 of 84 Old 05-26-2013, 03:14 PM Thread Starter
AM92
1992 XJ Cherokee
Originally Posted by Diamond-x View Post
Awesome snag!
Thanks!!
AM92 is offline
post #17 of 84 Old 05-26-2013, 03:16 PM Thread Starter
AM92
1992 XJ Cherokee
What was very unfortunate though when I was trying to unload it at my home my rear ujoint and adapter to the rear 8.25 snapped!!
AM92 is offline
post #18 of 84 Old 05-26-2013, 05:07 PM Thread Starter
AM92
1992 XJ Cherokee
Look at the plates inside the driver's side door for specific gearings or limited slip diffs.
Code Capacity Ratio
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
L - Limited Slip Differential
C - Conventional Differential
I can't pull axles at my JY because all the vehicles rest on the axles on top of old wheels and you can't bring in jacks. Spray bottle with a 50/50 mix of acetone and ATF will go a long way on rusted or seized bolts though.
Motorcharge I was able to pick up an d4 out of a 97 ford explorer now is there
dimensions anywhere I can weld the perches on or is it pretty much eyeballing to see where it fits.
AM92 is offline
post #19 of 84 Old 05-26-2013, 05:10 PM Thread Starter
AM92
1992 XJ Cherokee
http://www.ruffstuffspecialties.com/...g/88ss-31.html what does anyone think of ruff stuff?
AM92 is offline
post #20 of 84 Old 05-26-2013, 05:17 PM Thread Starter
AM92
1992 XJ Cherokee
AM92 is offline
post #21 of 84 Old 05-26-2013, 05:25 PM
austin6137
1990 XJ Cherokee
that looks like a d35
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #22 of 84 Old 05-26-2013, 06:39 PM Thread Starter
AM92
1992 XJ Cherokee
D35 is round my axle looks alot like the 8.25 kinda squarish on the top and bottom with the plug
AM92 is offline
post #23 of 84 Old 05-26-2013, 08:48 PM
Motorcharge
That is a 35. 8.25 has a very distinct bottom, it's round in the rear like the 35 but has the flat bottom. The pinion yoke gives it away though. You don't have the square tabs at the top that the 8.25 has.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #24 of 84 Old 05-26-2013, 08:52 PM
cory4um
I thought he clearly pulled the axle from a 97 explorer?
That may be the original 35 tho that came with the jeep.
cory4um is offline
post #25 of 84 Old 05-26-2013, 08:59 PM Thread Starter
AM92
1992 XJ Cherokee
I havent installed the 8.8 yet but I guess the turdy5 couldnt wait any sooner to go out on me
AM92 is offline
post #26 of 84 Old 05-26-2013, 09:03 PM Thread Starter
AM92
1992 XJ Cherokee
I have decided though I'm picking this kit up http://www.ruffstuffspecialties.com/...Category_Code=
differential cover as well http://www.ruffstuffspecialties.com/catalog/88DCOV.html
and everything else at a local 4x4 shop near me Ill keep you guys posted
AM92 is offline
post #27 of 84 Old 05-26-2013, 09:16 PM
cory4um
My turdy5 has been screaming at me for the past 80k miles, well since i bought the jeep. It refuses to quit on me tho,fortunately Unfortunate? Lmao
cory4um is offline
post #28 of 84 Old 05-26-2013, 10:58 PM Thread Starter
AM92
1992 XJ Cherokee
80k? lol just hanging in there by a thread much
AM92 is offline
post #29 of 84 Old 05-27-2013, 07:31 AM
billb2011
I just thought I would throw this out there since I didn't see anyone else mention it. When deciding which gears to go with on an 8.8 this is one thing to consider. There is a difference apparently between the carriers on limited slip and open. I want to get an 8.8 for my xj and put a spool in it. I found that if I get a 4.10 with open carrier I can put a mini spool in it which costs 100 bucks or so and wont have to pull the ring gear. If you have a 4.10 with limited slip you would have to put a full spool in it which cost considerably more and you have to pull the ring gear to put it in. I am assuming that a locker is the same deal? You probably have to have an open carrier if you want to put in a lunchbox style locker?
"If you lend somebody $20 and you never see that person again, you might consider that money well spent." ~unknown
billb2011 is offline
post #30 of 84 Old 05-27-2013, 10:06 AM Thread Starter
AM92
1992 XJ Cherokee
Originally Posted by billb2011 View Post
I just thought I would throw this out there since I didn't see anyone else mention it. When deciding which gears to go with on an 8.8 this is one thing to consider. There is a difference apparently between the carriers on limited slip and open. I want to get an 8.8 for my xj and put a spool in it. I found that if I get a 4.10 with open carrier I can put a mini spool in it which costs 100 bucks or so and wont have to pull the ring gear. If you have a 4.10 with limited slip you would have to put a full spool in it which cost considerably more and you have to pull the ring gear to put it in. I am assuming that a locker is the same rdeal? You probably have to have an open carrier if you want to put in a lunchbox style locker?
yea there is a difference between limited slip and open but since I am regearing wouldn't I need a different setup? The 8.8 i picked up is geared 3:73. I'm fairly new to lockers and stuff if anyone can explain or what other People have on thier set up
AM92 is offline
8.8 , hpd30 , jeep , np231 , xj
