Going doorless. Ideas for wiring connectors? - JeepForum.com
post #1 of 11 Old 04-23-2011, 11:17 PM Thread Starter
zatch83
1992 XJ Cherokee
I will be removing all 4 doors on my XJ in the next few days. I got a soundbar to put up on the ceiling that will replace the front door speakers. That will be a challenge in itself. But for now, I'm planning on cutting the door wires and putting some type of quick connector on them. Does anyone have any good ideas as to what type of connector to use? I just need the right tool for the job. Thanks!
... /_(_)_(_)_(_)_(_)_/
...|[ŻŻŻŻŻŻŻŻŻŻŻŻŻ]|
...|[_____________]|
..//ŻŻŻŻŻŻŻŻŻŻŻŻŻ//
.//_____Jeep____//
|[O]||||||||||[O]|
zatch83 is offline
post #2 of 11 Old 04-23-2011, 11:51 PM
jcooklock
1990 XJ Cherokee
When I had my xj and I took my doors off I used cupling connectors from radio shack
http://www.radioshack.com/family/ind...goryId=2032286
by JDNightFox - The terminal velocity of the square headlights is directionally preportional to the force of gravity decelerating the front wheels while the alternator is spinning at 3000 rpm's, minus the friction of the bumper pushing against the airflow with the 13 volt current the steering column is using during the time the vacuum motor is disengaged, but the mirrors must be directionally angled from the driver's window because the hood latches deflect the light refractioning down through the Nitrogen coat on the hood.
jcooklock is offline
post #3 of 11 Old 04-23-2011, 11:57 PM
jcooklock
1990 XJ Cherokee
I found a pic of how I did it.
post #4 of 11 Old 04-24-2011, 12:32 AM Thread Starter
zatch83
1992 XJ Cherokee
Oh awesome. Thanks! Did you put any kind of cap on them to keep dirt and water out? Just tape...?
..//ŻŻŻŻŻŻŻŻŻŻŻŻŻ//
.//_____Jeep____//
|[O]||||||||||[O]|
zatch83 is offline
post #5 of 11 Old 04-24-2011, 01:56 AM
RickyN29
RickyN29's Avatar
Check out waytek wire, they should have a good solution.
I've been thinking of doing the same. I hate having to pop the kick panels off and unplug each time.
1990 XJ Laredo 4x4 Auto
*Rusty's ~6" Lift
*Dana30/Dana44 3.55's
*Pacer Wheels/High-Tec Retreads 31" MT
*KargoMaster Safari Rack
*CSF Open Cooling System Conversion
*Hayden Tranny Cooler
*Flowmaster 40 Delta & High-Flo Cat
*PORC SYE / FRT DS Combo
*The Doors are off again for summer!
RickyN29 is offline
post #6 of 11 Old 04-24-2011, 02:35 AM
Project1
I know on my 98 -- I took the plastic near the floor off (in the cab not on the door) and there is a harness that just unplugs .. 2 seconds .. really easy .. plug it back in later
Project1 is offline
post #7 of 11 Old 04-24-2011, 09:53 AM
DeftwillP
So my buddy just showed me the perfect fix for this. There are plastic grommets that are in a hole behind the taillights that are the same exact size. Just pop some out at the junkyard next time you're there. They usually won't charge you for them.
DeftwillP is offline
post #8 of 11 Old 04-24-2011, 12:22 PM
Brookhart63
It is going to take the same amount of time pretty much to unplug from the kick panel I think.
Bought not Built
Jeep Outdoor Club of Cental Iowa
Square Headlight Jeep Club
Brookhart63 is offline
post #9 of 11 Old 04-24-2011, 02:20 PM Thread Starter
zatch83
1992 XJ Cherokee
Thanks for all the great ideas!
Secondary question now: what about the courtesy light door switches? Is there simply a fuse to be removed or can they be disconnected neatly? Or will I need to go cutting wires?
..//ŻŻŻŻŻŻŻŻŻŻŻŻŻ//
.//_____Jeep____//
|[O]||||||||||[O]|
zatch83 is offline
post #10 of 11 Old 04-24-2011, 02:34 PM
Brookhart63
They just thread out then disco that connector as well
Bought not Built
post #11 of 11 Old 04-24-2011, 03:22 PM
wolfepack215
wolfepack215's Avatar
1987 XJ Cherokee
No need to unscrew the door pin switch.... Above the kick panel on each side is the wire, (black/white 87-92) its a single wire and has a detachable plug.... if you want to make it easier, cut the quick connects off and put in micro toggle switches... Thats how I did it.... Take doors off, flip the switches to kill the light!
wolfepack215 is offline
connector , door removal , doorless , wiring
2 wiring connectors not connected 00 XJ Automatic bds5 XJ Cherokee Technical Forum 2 03-11-2011 08:13 AM
doorless power window wiring. Kingsleythe3 XJ Cherokee Technical Forum 8 07-27-2007 01:02 AM
Need ideas on half doors formy doorless xj muddyjeepguy85 XJ Cherokee Technical Forum 1 02-22-2006 09:11 PM
Need ideas on half doors for my doorless xj muddyjeepguy85 XJ Cherokee Technical Forum 4 02-22-2006 08:50 PM
doorless ideas ATX XJ XJ Cherokee Technical Forum 15 12-25-2005 09:05 PM
