[ Glove box Lighting, Floor Lighting ] - JeepForum.com
post #1 of 13 Old 02-10-2011, 09:00 PM Thread Starter
Grizzy98
standard and optional equipment for the 98 Cherokee...it says the glove box is supposed to be equiped with a light.
I just took mine off to see if I could find a burnt bulb...but can't see anything at all. Maby because it's a canadian model it doesnt have the Illuminated glove box...i just dont know.
http://www.cars.com/jeep/cherokee/19...=USA80JES042B0
copy and paste link for it to work.
Grizzy98 is offline
post #2 of 13 Old 02-10-2011, 09:21 PM
Degra101
dead link.
Degra101 is offline
post #3 of 13 Old 02-10-2011, 10:32 PM
hubs97xj
1997 XJ Cherokee
My 97 Sport has a lamp above the glovebox, but does not the "courtesy" lights for the foot wells. I'd take what I read on that site with a grain of salt- they list several things as standard that I have never seen on a later model. Rub strips on the bumper, step bumper, rack and pinion steering, etc.
hubs97xj is offline
post #4 of 13 Old 02-10-2011, 10:55 PM Thread Starter
Grizzy98
Yeah...I found a better site. http://autos.yahoo.com/jeep/cherokee.../features.html
says that even the se model has glove box lighting.
i still should have found it when I checked.
Grizzy98 is offline
post #5 of 13 Old 02-11-2011, 06:04 AM
xjokee
My '98 base model doesn't even have power windows. It has no glove box light. This also had the worlds largest gas gauge in the idiot light cluster (until I swapped it out). The link you show is for the 'Sport' model which prolly contains more standard features than the base.
Mike
~ When in doubt........Throttle out! ~
xjokee is offline
post #6 of 13 Old 02-11-2011, 11:49 AM
99goldxj
My 99 Classic has lights below the dash, but no glove box light.
1999 Jeep Cherokee Classic
201k miles
4.5" IRO Lift kit, 31" MTR Kevlar's, Custom bumpers
99goldxj is offline
post #7 of 13 Old 02-11-2011, 11:53 AM
Yucca-man
My '89 Cherokee Pioneer had glovebox lights, but I don't recall if there were foot lights. I don't think so.
My '96 Cherokee Sport had glovebox and foot lights. However, it also had the four map lights in the overhead console.
My '96 Cherokee SE has glovebox lights.
:shrug:
Yucca-man is offline
post #8 of 13 Old 02-11-2011, 12:03 PM
Paradise XJ
1988 MJ Comanche
90 XJ - Laredo - has glovebox light and foot lights
88 MJ - Pioneer - has glovebox light, did NOT have foot lights but did have the wiring for them. I grabbed a couple from the JY and they plugged right in...and worked.
You may have the wiring there and have to do the same thing. On the earlier models it's up and tucked under the dash so you never really see the bare bulb. On the later models it has a little white transluscent diffuser, a tiny light fixture that you have to open and pull the bulb.
The glovebox light is right behind and above the inside latch...there may be an empty socket, or at least a wire.
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #9 of 13 Old 02-11-2011, 12:28 PM
Yucca-man
Good point about the wiring - I might just have to go look at my '96 now and add some lights.
post #10 of 13 Old 02-11-2011, 05:28 PM Thread Starter
Grizzy98
Grizzy98 is offline
post #11 of 13 Old 02-11-2011, 05:29 PM Thread Starter
Grizzy98
My 98 model doesn't have power windows...or locks. There is no floor illumination...or glove box lighting. It only has power...adjustable mirrors. It's actually pretty kool.
Grizzy98 is offline
post #12 of 13 Old 02-14-2011, 06:25 PM Thread Starter
Grizzy98
Grizzy98 is offline
post #13 of 13 Old 02-20-2014, 12:42 PM
JBVfromFK
my 99 sport has floor illumination, but no glovebox lamp that I can find. I will be looking again tonight, now that I think I know what the switch itself looks like. It is (apparently) OEM #4565022, and a google search will bring up images. it looks like it was used in a bunch of Chrysler/Dodge/Jeep applications. Considering how much unused wiring is waiting for upgrades that I don't have, I am hoping to find the wiring for this switch/lamp combo just waiting for me.
Edit- I found a junkyard '98 with a glovebox light. There is a hole in the sheet metal for it right next to the glovebox latch. My 99 does not have the hole, or the wiring, although the glove box door does have the "push point" molded into the plastic. It will take some cutting and splicing to make it work.
Jeeps make me happy.
JBVfromFK is offline
Help me with my lighting set up Beowill XJ Cherokee Technical Forum 11 12-05-2010 11:51 AM
Aux Lighting muddigger16 XJ/MJ Cherokee Non-Technical Forum 4 04-26-2009 01:56 PM
lighting??? jeepjack6932 XJ Cherokee Technical Forum 11 05-13-2007 09:43 PM
Aux. Lighting BeachinXJ XJ Cherokee Technical Forum 2 12-31-2003 09:11 AM
XJ Lighting ? xwejx XJ Cherokee Technical Forum 1 08-15-2003 06:32 PM
