Getting that oil filter adapter bolt out. - JeepForum.com
post #1 of 5 Old 11-09-2007, 03:41 PM Thread Starter
kpjoyce
My oil leak from the bad oil filter adapter o-ring is getting bad. I need to get that replaced.
I tried it once before, but got frustrated when I couldn't get a tool on it and leverage at the same time. This time, I'm thinking that I'll need to take the engine mount loose and jack up the engine to get the clearance I need to remove that dang bolt.
I'm worried about the bolt, though. I'm worried that I might break off the bolt trying to take it out. I'm hoping that you'll tell me that I'm stupid to worry about that.
kpjoyce is offline
post #2 of 5 Old 11-09-2007, 03:50 PM
rstarch345
Try this out http://www.yuccaman.com/jeep/filter.html
2K XJ - 6" lift w/ 34s
'98 XJ Laredo - Stock (and staying that way)
'71 M151
I'm a proud member of
rstarch345 is offline
post #3 of 5 Old 11-09-2007, 04:25 PM
citRon
2003 KJ Liberty
I had to use a 3 foot long pipe over my wrench to break it loose.
citRon is offline
post #4 of 5 Old 11-09-2007, 04:26 PM
4.0H.O.XJ
Dude,
I removed the one motor mount bolt that is directly in line with it, and I had plenty of room to work. Didnt have to jack the motor or anything. fairly straightforward, but yeah, that bolt is a biznitch.
......its gonna be tight all the way to the last twist, too. There is a smaller O ring on the shaft of the bolt that binds all the way out. Dont sweat it, go slow, dont panic. Maybe crack it forward before you back it off to loosen it up.
Good luck.
4.0H.O.XJ is offline
post #5 of 5 Old 11-09-2007, 11:27 PM
ChewyXJ
nom nom nom
ChewyXJ's Avatar
Forgive me if I didn't notice but what year is your Jeep? Different years have different fasteners.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount
'97 Cherokee Sport 5spd,231, white, stock
'90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc.
'87 XJ 2" lift
'96 XJ stock
"Personally, I've learned so much from my mistakes, I'm thinking of making some more."
"Don't believe everything you think..."
ChewyXJ is offline
Oil filter adapter torx bolt JeepJinx XJ Cherokee Technical Forum 5 05-21-2009 06:28 AM
Oil Filter Adapter bolt lasvegasoffroad XJ Cherokee Technical Forum 8 12-17-2008 09:24 PM
Oil Filter Adapter Bolt! sgt. Slaughter XJ Cherokee Technical Forum 3 01-18-2006 12:34 PM
Oil filter adapter bolt problem justaregularguy XJ Cherokee Technical Forum 5 07-12-2005 05:52 PM
Torque spec for '00 XJ oil filter adapter t-60 bolt? Hellspawn XJ Cherokee Technical Forum 3 06-17-2004 05:00 PM
