Getting 6-8 mpg, what could be wrong? - JeepForum.com
post #1 of 19 Old 03-11-2013, 05:24 PM Thread Starter
Ansleigh
1995 XJ Cherokee
95 XJ, v6 engine 4.0L 120K miles
Ive had my jeep for 4 years, and it usually gets around 14 mpg around town but lately its mileage has been horrible and its doing some other weird things! I'm a college student, so this is the only mode of transportation I have right now, and I would feel a whole lot better if I could get bonnie running well again! Here's the symptoms:
-I'm getting 6-8 mpg
-The air reeks of gas everytime I get out of it after I drive it
-The engine never misfires, but it does idle pretty hard sometimes
-It's taking longer to crank than it used to
-Sometimes I hear a knocking noise after I turn the car off
Side note- I just had an oil change and all my fluids topped off, and it doesnt leak any kind of fluid
Anyone have any ideas about what could be wrong?
Thanks so much!
Ansleigh is offline
post #2 of 19 Old 03-11-2013, 06:07 PM
bigbill888
Did it start doing this immediately after the oil change?
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #3 of 19 Old 03-11-2013, 06:25 PM
xtremzj
Change your o2 sensors.
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #4 of 19 Old 03-11-2013, 06:53 PM Thread Starter
Ansleigh
1995 XJ Cherokee
bigbill888- No, it was doing this before also, I thought the oil change might help (plus it was due for one anyways) but no luck
xtremzj- I actually have an O2 sensor that I tried to put on myself when I tuned up the jeep when I first got it, but couldnt get it on. I guess its time to bite the bullet and pay a mechanic to do it for me- Thank you for the advice!
Ansleigh is offline
post #5 of 19 Old 03-12-2013, 01:41 AM
Paulio91184
1992 XJ Cherokee
Yea man, most likely it's your 02 sensors...If they aren't working correctly they make your engine run WAY rich
WHITE JEEP CLUB MEMBER #2112
1992 Jeep Cherokee Police Package
3.5" Rubicon Express Superflex with RE Monotubes, Ford 8.8 Rear Axle, 33x12.50 General Grabber AT2's, RE Gen 2 quick disco's
Paulio91184 is offline
post #6 of 19 Old 03-12-2013, 12:18 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Are all of your tune-up parts fresh ?
Have you inspected for a cracked exhaust manifold ?
Is the Catalytic Converter working ?
Change your O2 sensors.
CJ7-Tim is offline
post #7 of 19 Old 03-13-2013, 10:43 PM Thread Starter
Ansleigh
1995 XJ Cherokee
CJ7-Tim Thanks for the advice!
-I think the tune up is fairly new- I replaced all of the spark plugs when I had to replace a cracked distributor head 3 years ago (is that new enough considering Ive only put 9000 miles on the car since then?)
-I wanted to see what all yall experts had to say before I jumped to any conclusions, but I was very suspicious of my catalytic converter, especially since a mechanic told me I needed a new one because mine was starting to go bad 2 years ago, but my dad chose to ignore the advice and let it be.
-I have the O2 sensor to put on, and am going to make some more attempts to convince my dad to pay for the catty.
-And I will look into this exhaust manifold- where would I find it on the car? I put in a new exhaust system (muffler and pipes) when I got the car because the muffler was so rusted that I could fit my fist inside the holes in it, and all the pipes were just as bad.
Ansleigh is offline
post #8 of 19 Old 03-13-2013, 11:06 PM
x91evo
the other problem is you have a V6 cherokees came with an I6 lol
x91evo is offline
post #9 of 19 Old 03-13-2013, 11:34 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
mine didn't come with an I6 and has a V6.
***Chris***
chris87xj is online now
post #10 of 19 Old 03-13-2013, 11:42 PM
ss427ci
The exhaust manifold is on the drivers side underneath the intake manifold. It will probably be very difficult to spot a crack with it on, but if you listen close you might be able to hear an exhaust leak and that would be a clue.
3 years is a long time, but with that mileage, idk. It'll just depend on the current condition of the parts and plugs, if it looks good, keep it.
X2 on the O2 sensors, they can cause all of your problems.
You might also check for any injectors leaking because of worn or cracked o-rings. With engine running look for any fuel leakage around each injector.
2001 Cherokee XJ - Metalcloak/Hutchinson/ARB/OME/JKS/LII/IRO/Napier/Browndog/Trucklite
ss427ci is offline
post #11 of 19 Old 03-13-2013, 11:50 PM
ss427ci
The GM V6 was used from 84-86, but there is no way his 95 is. It is most definitely a 4.0L I6
ss427ci is offline
post #12 of 19 Old 03-13-2013, 11:52 PM
x91evo
I would say O2 sensor not sensors lol dont need to waste any money.
The only one that would vary engine performance is the 1st one upstream. Not the one after the cat, that one is pretty much useless
x91evo is offline
post #13 of 19 Old 03-14-2013, 12:06 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
***Chris***
post #14 of 19 Old 03-14-2013, 10:07 AM
habbyguy
I'll just jump in and add my agreement with the good advice above.
1) Replace the O2 sensor (cheap, and it might well improve your gas mileage even if it's not the root cause of the "big problem". At $4 a gallon, it'll pay for itself in very short order either way.
2) Really, really check for an exhaust leak. The fact the OP had a very rusty exhaust system, and that it's been replaced both point to the possibility of a cracked exhaust manifold (assuming it was rusty and weakened as well, and that the torque of wrenching in that new exhaust system probably cracked it).
3) It's always a very good idea to learn about your vehicles. I see "V6" references on all sorts of vehicles that never had 'em, 2002 and up "Cherokees", etc.
4) Cats seldom actually fail - most times it comes down to an O2 sensor or other issue (cracked manifold)
5) A new tubular header will replace the nasty old iron exhaust manifold for not too much money, and it'll look better, weigh less, and improve performance and efficiency. It's not a huge job to install it, and is something I did based on my MPG dropping from about 24 on the road down to about 18, even though I couldn't really hear an exhaust leak. My manifold was cracked, and the header fixed my mileage issue (and looks cool, to boot).
habbyguy is offline
post #15 of 19 Old 03-14-2013, 02:04 PM
bobbo_xj
Cat deserves to at least be tested. Sucky mpg, rich exhaust, mechanic previously telling you it is failing. Of course you could have other problems. If you replaced your upstream O2 sensor and spark plugs and have good gasoline, and want to chance it that those items are ok then focus on the cat and failing cat symptoms. Might want to wonder why cat has been going bad though. Caveat: I am no expert, but google helps.
2001 XJ Sport, 176k mi.
bobbo_xj is offline
help please , mileage
