GEN light on - JeepForum.com
post #1 of 3 Old 05-30-2011, 10:20 PM Thread Starter
psychoteen101
GEN light on
My Cherokee is having an intermittent problem with the charging system. The gen light will come on randomly when driving, but if i shut the vehicle off, then restart it, it will go off for a while, then eventually comes back on. The voltage guage reads extremely low. Like around 9 volts. It doesnt run rough or anything, so im almost thinking its not the alternator. Maybe a false reading? Im thinking the next step is to obviously see what the output voltage of the alternator is actually reading. If its still ok, what could the problem be? Voltage regulator possibly?
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #2 of 3 Old 05-31-2011, 05:05 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
*I always verify this with a meter at the battery to be sure it is real. Only takes a minute. You really need confirmation.
*Be sure all connections including battery, grounds and alternator are tight and corrosion free.
The "target" voltage that you should have with a healthy battery and charging system is around 13.5 to 14.0 volts.
Low voltage is almost always alternator related. If the voltage regulator goes south (located inside the computer), that usually results in an unregulated charging condition, which would be high voltage, not low.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #3 of 3 Old 05-31-2011, 08:04 AM
justanotherjpr
X2 check all grounds especially the mesh strap at the back of the head leading to the firewall.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
Drivers side brake light/running light/ blinker all not working. 2doorxj XJ Cherokee Technical Forum 6 11-02-2009 08:25 AM
passenger rear brake light and reverse light not working 1limited XJ Cherokee Technical Forum 4 10-18-2009 05:19 PM
Emergency Brake light, ABS light and Airbag light stay on after starting 2001 4.0. s4ryanl1 XJ Cherokee Technical Forum 5 02-14-2009 06:42 PM
Tail Light / Turn Signal / Brake Light Problem swdmus XJ Cherokee Technical Forum 1 12-03-2008 04:09 PM
Airbag Light, Check Engine light, Gauges go dead.... OhioSpyderman XJ Cherokee Technical Forum 11 09-14-2005 09:50 AM
