Gears. Help me choose! - JeepForum.com
post #1 of 8 Old 06-05-2013, 06:24 PM Thread Starter
KalebJohnson
1995 XJ Cherokee
I know I've asked this before but the time has come to finally get new gears.
I'm running 33's with a d30 and d44 with 3.55 gears currently. I'm mainly using my Jeep to daily and lightly wheel while I'm in school, and driving it back to VA in November.
It is an Auto (not sure if that matters) but curious as to what gears are recommended and if I need a new carrier or not and what ever else may be needed?
Thanks guys!
KalebJohnson is offline
post #2 of 8 Old 06-06-2013, 09:01 AM
TheBoogieman
Devil's Advocate
TheBoogieman's Avatar
4.56.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #3 of 8 Old 06-06-2013, 11:30 AM
ibjeepin95
Originally Posted by theboogieman View Post
4.56.
x2
ibjeepin95 is offline
post #4 of 8 Old 06-06-2013, 11:59 AM
Jeep_Tech
I say put 35s on it and go 4.88. you know you will eventually want 35s anyways
Jeep_Tech is offline
post #5 of 8 Old 06-06-2013, 12:04 PM
lazyxj
x2
I have 33"s and have run then on 4.11s and now, after regearing, 4.56s.
The mileage didn't change much and it runs better, without a lot of downshifting. Surprising thing is when I run the second set of wheels( 31"s) , the mileage stays the same and it's a lot more fun to drive...as long as I keep my foot out of it.
4.0s like running between 2200-2600 RPMs.
If you plan on keeping and building it, when time and money are available, you will be a lot happier with 4.56s.
2001 Sport, 4" lift, 33 X 10.50 KOs, R.E. DB, R.E.-UCA, JKS-LCA, ACOS, 8.25-4.56-TruTrac, SYE, D-30 E-locker w/alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Lots of armor, Towing baseplate.
lazyxj is offline
post #6 of 8 Old 06-06-2013, 06:26 PM Thread Starter
KalebJohnson
1995 XJ Cherokee
Thanks guys. Will I need to get new carriers also?
post #7 of 8 Old 06-06-2013, 06:54 PM
sluff28
1975 CJ5
when I find some one to do the gears on mine I will be going with 4.56
sluff28 is offline
post #8 of 8 Old 06-06-2013, 06:56 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Go 4.88. You'll never know where your jeep build leads you. And if you're going to buy new carriers go for the ones that say ARB on them.
Luck Favours The Prepared
Anticanman is offline
