Gearing: Any reason to think... - JeepForum.com
post #1 of 8 Old 01-09-2008, 09:31 AM Thread Starter
babyfood1217
...that I have a rear gearing other than 3.07? 1990 XJ with D35 with 4.0L/5-speed, so based on the fact that I never touched the rear axle/diff/gears/carrier/etc... would I have any reason to assume the PO did anything? When I was driving it I get getting 18-20 mpg with 235/75-15s Have I done my research correctly, or might my gearing be different?
-Chris
babyfood1217 is offline
post #2 of 8 Old 01-09-2008, 09:36 AM
rocketman121
Jack up the rear end, rotate the tire once, and count how many times the drive shaft spins. If its 3x, then you have 3.07s.
-87 XJ 4.0 5spd, 2"BB, 31" BFG ATs on 15x8 Eagle 058s, trimmed and doorless
-01 TJ 4cyl auto FT 3" lift 33" Goodyear AT/S & BFG muds herculined tub
rocketman121 is offline
post #3 of 8 Old 01-09-2008, 10:05 AM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
It should be 3.07's, but I "think" if it had the tow package, you got 3.73's.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline
post #4 of 8 Old 01-09-2008, 08:37 PM
bikedude189
1993 XJ Cherokee
uh... look at what the diff tag says?
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline
post #5 of 8 Old 01-09-2008, 08:40 PM
SamO
I have a 1989 w/ 4.0 and 5 speed and I have 3.07s. You could try the driveshaft method to be sure, but I am pretty positive you have 3.07s, unfortunately.
Originally Posted by Kyoseki
I really don't know where anyone gets the idea that they have a right to not be offended.
1989 XJ, 4.0, 5 speed, 4x4, 3inch lift, 31s, Rear leaves from a '99, No cat, glasspack with a turndown right under the passenger seat. ARB bull bar with Warn winch. FOR SALE!
NEW! 1998 XJ 4.0 5spd, 4x4, Up Country package, bone stock w/ a badass stereo.
SamO is offline
post #6 of 8 Old 01-09-2008, 08:51 PM
gradysjeep
gradysjeep's Avatar
Its a 1990 that means its 18 years old. The diff tag is probably gone and has been gone for some time.
gradysjeep is offline
post #7 of 8 Old 01-09-2008, 09:29 PM
Willy36
1990 XJ Cherokee
i believe the towing package was automatic only. my 90 w/ 4.0 and 5 speed has 3.07.
Willy36 is offline
post #8 of 8 Old 01-09-2008, 11:19 PM
lifted92xj
lifted92xj's Avatar
1992 XJ Cherokee
pretty sure the 5spd didnt have the tow package option..but even in the autos with tow package there 3:55
big lift, sick tires, awsome accessories, alot of custom work.
my jeep won the war, your honda mows my lawn
lifted92xj is offline
8.25 snapped......for no reason Beefcake7777 XJ Cherokee Technical Forum 20 12-21-2009 06:06 AM
96 XJ 4.0 Dies for no reason please help ilikepie XJ Cherokee Technical Forum 2 08-05-2009 08:45 PM
For some reason I want to buy this BigDaddyChia XJ Cherokee Technical Forum 13 02-27-2007 12:06 PM
Wits end for a different reason... k00laydrulz2k6 XJ Cherokee Technical Forum 9 10-21-2004 01:53 PM
what would be the reason for... xcmbike XJ Cherokee Technical Forum 13 09-05-2003 07:58 AM
