Gear Ratio for 33's/AW4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Gear Ratio for 33's/AW4
JKS Flex Connect in Actions!CCOR is Hiring! Athens, GA!ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 01-30-2010, 07:15 PM   #1
mule13
Junior Member
mule13's Avatar
1987 YJ Wrangler
To plan for an upcoming build what would be a suitable ratio for my Cherokee XJ with the 4.0/AW4 running 33x12.5x15's?
The XJ will be my daily driver going at least 50 miles a day for school/work. Id like something thats going to be easy to drive on road daily but still perform well when i wheel on the weekends.
im leaning more towards 4.10's or 4.56's whats your opinions?
(D30 Front / Ford 8.8 Rear)
Also: Anyone run Aussie Lockers front and rear on a daily driver? Is it rough driving on the street and does it add any wear to the tires?
mule13 is offline   Reply With Quote Quick reply to this message
Unread 01-30-2010, 07:38 PM   #2
Bertamus
1992 XJ Cherokee
I'd go 4.10. I'm running 3.73 with a 5 speed, and find thats perfect for the street IMO and just right for the trail. I have low when i want to go lower
92 XJ, 3.5 RC Lift, Full Packs, JKS Discos, IRO Trac Bar, D30 HP, Ford 8.8 w/ discs, 31x10.50 KM2's on D Windows, JCR Front Bumper and Tie-ins, Custom built Rear Bumper, Warn 10k winch
Bertamus is offline   Reply With Quote Quick reply to this message
Unread 01-30-2010, 07:47 PM   #3
mule13
Junior Member
mule13's Avatar
1987 YJ Wrangler
Yeh thats what i was leaning towards.
Thanks for your input (:
Unread 01-30-2010, 07:50 PM   #4
EricsXJ
The Post man
EricsXJ's Avatar
4.56 and nothing lower
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website - EricsXJ.com
EricsXJ is offline   Reply With Quote Quick reply to this message
Unread 01-30-2010, 07:56 PM   #5
mule13
Junior Member
mule13's Avatar
1987 YJ Wrangler
I was also considering the 4.56's, But my dad runs 4.56's in D44's with 33's in his YJ with a 5 speed and by 5th gear hes running at about 60MPH at 2.5k Revs. Just seems a little low for me maybe if i was running 35's it would seem better.
Ill still look into it thought and i appreciate your reply (:
Im a big fan of your XJ btw shes a brute.
Unread 01-30-2010, 08:05 PM   #6
EricsXJ
The Post man
EricsXJ's Avatar
Thanks.
For the gears you should compare apples to apples. I have had that setup: 4.0L/AW4/4.56 and 33's and it was close to feeling like stock again. In reality I wouldn't have minded even a little lower (4.88).
Don't be afraid to go with lower gears. If you don't and opt for the 4.10s you will likely regret it later. You will be hard pressed to find anyone that went with 4.56 and regretted it because it was too low.
Eric
Unread 01-30-2010, 08:15 PM   #7
mule13
Junior Member
mule13's Avatar
1987 YJ Wrangler
Thanks.
Ill take it from your experience with that setup and ill opt for the 4.56s. I think i would be happy with the 4.10s but just to be safe and future proof me ill run the 4.56's in case i ever do decide to run 35's or larger.
Thank you again (:
Unread 01-30-2010, 08:35 PM   #8
xjfever
xjfever's Avatar
1995 XJ Cherokee
With the 5 speed you want to go one ratio lower than with the auto. I would go with the 4:56's in your case for sure. I run 4:88's with the 5 speed and 32's on the TJ but it has the 4 cyl. and needs all the torque available. Like Eric said I have never seen anyone unhappy with the 4:56 gears and the AW4.
xjfever is offline   Reply With Quote Quick reply to this message
Unread 01-30-2010, 09:22 PM   #9
89eliminator
1989 MJ Comanche
i like my 4.10s.
WI4x4.com
89eliminator is offline   Reply With Quote Quick reply to this message
Unread 01-30-2010, 10:43 PM   #10
the_weirdo
I'd go with 4.56 gears. I have 33's with the AW4 and I wish I went with 4.88s.
the_weirdo is offline   Reply With Quote Quick reply to this message
Unread 01-30-2010, 11:15 PM   #11
bigbike
1995 XJ Cherokee
4.56-4.88, if you wheel/carry camping/wheeling gear Id go 4.88. I have 4.56 with my 4.0, ax-15, and 34s and I definetly like the 4.56 but it would of been nice to go 4.88 for extra gearing while wheeling.
bigbike is offline   Reply With Quote Quick reply to this message
Unread 01-31-2010, 05:02 AM   #12
xjfever
xjfever's Avatar
1995 XJ Cherokee
Originally Posted by 89eliminator View Post
i like my 4.10s.
You would love 4:56's.
Unread 01-31-2010, 09:39 AM   #13
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Me, too. Granted, my XJ is heavy and the engine a little tired at 200K. With stock weight and a fresh mill I'm sure the 4.56 would be fine.
Really, the only problem I have is the need to downshift to 3rd on the hiway more than I would like (I generally drive 55-60 and never more than 65). FWIW, my RPMs are exactly 2250 at 65 mph via the GPS.
PS: There is no way I would go any higher (numerically lower) than 4.56. I had a full set of 4.11s ready to go, then reconsidered and went 4.56.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline   Reply With Quote Quick reply to this message
Unread 01-31-2010, 09:48 AM   #14
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Do you have the 8.8 yet? You never mentioned if you already have one or not.....
If not, why not get one with the 4.10's in it and try it first?
If the 4.10's are good enough for right now, then either grab a 4.10 dana 30, or leave the front driveshaft out for a while until you regear etc.
Gearing is an expensive hobby, so if you can see how you like the 4.10's before spending a penny, that sounds like a good idea to me.
Just a thought....But surprised no one else asked if you already had the 8.8 or not, unless I slept through something.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
leftlanetruckin is offline   Reply With Quote Quick reply to this message
Unread 01-31-2010, 04:12 PM   #15
M4Madness
Definitely go with at least 4.56's. I'm running 32's with 4.56's and am turning a measly 2200 RPM's or so at 60 MPH. You'll be turning less than that with one inch taller tires.
M4Madness is offline   Reply With Quote Quick reply to this message
