#1 | |
Fuse Diagram for 2000 XJs
Having recently purchased a 2000 Cherokee Sport, I'm looking for a fuse diagram for the in-cabin fuse box. The manual refers to a card (either as part of the manual or at the box), and none is found in any location...
Aparently, from the people I've spoken to, this is a rather common problem... The service manual from the local Jeep dealership isn't of much help, as the book references circuits within the book. The only way to make any use of the chart is to own the service manual... I'm hoping someone has something they can help with... I'm not looking for any fuse in particular, but a mapping of "fuse n is responsible for circuit x" for the 20+- fuses in the cabin... Any help, either in direct answer or references to other resources is greatly appreciated.. Thanks so much...
#2 |
The Post man
Welcome to the forum!
Unfortunately you are correct. There is no diagram other than whats in the FSM.
I'm not very skilled with electronics but looking at my FSM I think this is what the fuses go to in the junction block which is inside the jeep: #1(25A) - aux power outlet #2(25A) - cigar lighter #3(10A) - left headlamp, fog lamp relay #4(10A) - left headlamp #5(10A) - right headlamp, daytime running lamp module #6(5A) - trans slector switch illumination, transfer case switch illumination, instrument cluster, radio, rear wiper, A/C-heater control, rear window defogger, front fog lamp switch, and extended idle switch(police pkg) #7(10A) - left marker lamps/turn signals, fog lamp relay, fog lamp switch, trailer tow connector, license lamp, left tail/stop lamp #8 - spare (switched circuit - start/run) #9(10A) - compass, sentry key immobilizer module, headlamp delay module, instrument cluster #10(15A) - back-up lamp switch, transmission range sensor(4.0L A/T), daytime running lamp module, duty cycle evap/purge solenoid(gas), radiator fan relay, A/C compressor clutch relay, oxygen sensors #11(20A) - powertrain control module, transmission control module, automatic shutdown relay, fuel pump relay #12(10A) - combination flasher, instrument cluster #13 - spare (not switched - connected directly to battery) #14(10A) - power mirrors, rear window defogger switch #15(25A) - passenger power lock/window switch #16(10A) - right headlight #17(15A) - radio #18(10A) - heated seats, driver power lock/window switch, power mirror switch #19(10A) - clutch interlock switch and switch jumper, engine starter motor relay #20(15A) - trailer tow connector, trailer tow left/right turn relays #21(15A) - horn relay, horn switch, horns, overhead module, clockspring #22(20A) - rear wiper/washer switch, rear wiper motor #23(10A) - right front park/turn signals/side marker lamps, right tail/stop lamp #24 - spare (switched circuit - run only) #25(15A) - blower motor relay, blend door actuator, shift lock solenoid, extended idle(police pkg), A/C-heater control, controller anti-lock brake and relay #26(10A) - airbag control module #27(10A) - airbag control module #28(25A) - power lock/window switches #29(25A) - power seat switches, heated seat relay #30(20A) - wipe/wash switch, front wiper motor Now go get a FSM to make sure I didn't make any mistakes! ![]()
Eric 2000 XJ "PROJECT RUBICON" lifted, locked, shafted, running 35's, 4.56 gears, pair of ARB's, and stock AM/FM cassette My website - EricsXJ.com
#3 |
Thanks so much!!
It may not be correct, but it's by far the closest thing I've seen yet.. I'll try to confirm in the next few days, and let you know.. (busy schedule, so I may not get it to it...) Thanks so much again!! Carl |
#4 | |
-Thanks Eric
98 XJ SE 4.0 L White 70,xxx miles RE 3.5in Super Flex Lift, BFG AT 32x11.5x15; adj Control arm, RE gen2 disco's, T-case drop
Factory Front Skid/ TC Skid/ Gas Skid; Cobra 18 WX ST II SoundTracker CB 3 FT firestick mounted on RoofRack; Set of BaJa lights top bumper mounted; Light bar/w 150watt KC DayLighters ;Rusty's Air intake; FM Delta 50 C 4X4 front tow hooks; Rear Hatch Speakers; Painted Fenders Flares; herculined floor; Back-Up lights inside bumper My car Domain Page |
#5 | |
The Post man
#6 |
just what I needed..... thanks!
#7 |
ah saved my ***, no dash lights = scary.
stupid manual says look at the fuse box door, fuse box door says look at the manual.... ugh. This place is the greatest lol |
#8 |
Here is what I have bookmarked:
http://www.jeepforum.com/forum/f11/2000-fuse-panel-designations-440689/?posted=1#post3995912
Patriot Blue 2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock 192,000 miles and counting http://i37.photobucket.com/albums/e65/mhall02/Mike%20Pics/Jeep1.jpg |
#9 |
If anyone is interested I combined the typed description above, with the fusecolors and layout pic from the link posted into a single image that you can keep in the glove box for reference.
#10 |
hope this helps......
![]() ![]() Last edited by chopsrubicon; 01-29-2009 at 09:45 AM.. Reason: forgot to add 2nd page |
#11 |
good call.time to look for my non working power doors...funny thing is power windows s till work :scratch:
1993 3dr XJ i6 4x4 , in the works but road-going :p MY THREADS [url]http://www.jeepforum.com/forum/showthread.php?t=520942[/url] [url]http://www.jeepforum.com/forum/showthread.php?t=515576&page=2[/url] [url]http://www.jeepforum.com/forum/showthread.php?p=4827827#post4827827[/url] [url]http://www.jeepforum.com/forum/showthread.php?t=521632[/url] |
#12 |
Jeeper!
Made a .jpg image of the fuse panel diagram and a pic of the fuse panel.
In case anyone was looking.
2000 Silverstone Metallic Jeep Cherokee Sport 4x4 (XJ) 2003 Flame Red Dodge Ram 1500 Quad Cab ThunderRoad Hemi My Facebook __________________ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
