Fuse box and relay diagram for 2001 Cherokee Sport - JeepForum.com
post #1 of 17 Old 05-01-2008, 09:44 AM Thread Starter
asolinger
I am hoping someone has a diagram for the Fuse Boxand relays for a 2001 Jeep Cherokee Sport 4x4.
Thanks
asolinger is offline
post #2 of 17 Old 05-01-2008, 10:23 AM
mjaybird65
here's a fuse reference that I bookmarked. maybe someone will find a diagram for ya.
http://www.naxja.org/forum/showthread.php?t=76389
2001 Black XJ Sport 4x4
4.0L I6, AW4, NP231, 8.25 rear
mjaybird65 is offline
post #3 of 17 Old 05-01-2008, 11:05 AM
mhall02
This may help some as well:
http://www.jeepforum.com/forum/showt...=1#post3995912
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #4 of 17 Old 03-17-2015, 11:57 AM
Dannee
2001 sport 4x4 160k miles. In great shape.
The clock/radio, overhead interior lights quit working at the same time. Several months ago the auto door locks unlock but won't lock. Checked all the fuses and they look good. Can fuses look good and still be bad? Should I replace them even though they look good?
Dannee is offline
post #5 of 17 Old 03-17-2015, 12:28 PM
CCKen
CCKen's Avatar
Thanks
Here's the PDC fuses. The PDC relays are identified on the cover of the PDC.
CCKen is offline
post #6 of 17 Old 03-17-2015, 07:14 PM
Kevin108
That's one to save to your smartphone, for sure. Thanks Ken!
My build thread has pics again. http://www.jeepforum.com/forum/f177/kevin108s-2000-xj-build-867428/
Kevin108 is offline
post #7 of 17 Old 06-15-2015, 09:45 AM
Omegacron
I had this same exact problem on my 1990 - turned out there was a short behind the radio. A couple of the wires rubbed enough to wear through the rubber coating on the wires, and once they were touching, first went the clock/radio, then the lights, then the doors, then later the A/C control panel.
What finally clued me in on it was that a I hit a hard bump (ran over a board on the freeway), and suddenly everything started working. I hadn't heard that radio in almost 5 years, and suddenly it just started playing.
Of course, I hit another big bump about two weeks later, and I was back to everything not working. At that point, I tore apart the dash looking or a loose wire or connection.
Omegacron is offline
post #8 of 17 Old 06-15-2015, 10:31 AM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Old thread, but here's the cabin fuse panel in case this thread gets found again.
***Chris***
chris87xj is online now
post #9 of 17 Old 06-16-2015, 12:47 PM
Semperfi75
Where?
Where is this fuse box located? I have one on passenger side kick panel that looks "nothing" like this and one under the hood, again nothing like this.. My Jeep is a 2000 Cherokee Sport...
Looking for front window washer fuse.. #30 ... ????
Semperfi75 is offline
post #10 of 17 Old 06-16-2015, 01:37 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
It's inside the front passenger side kick panel. Looks like the front washer is the 20amp in position 30.
Jeep Cherokee (XJ) 1997 - 2001 Fuse & Relay Information
Some of the panel may still be hidden if you only remove the access door.
You wouldn't by chance have a Grand Cherokee Laredo Sport would you?
***Chris***
post #11 of 17 Old 06-17-2015, 09:33 AM
Semperfi75
I found the fuse box, but mine looks totally different than this and have no #30 position. Unless it's tuck way up behind the plastics.. No I have a 2000 Jeep Cherokee Sport..
tks
post #12 of 17 Old 06-17-2015, 09:54 AM
CCKen
CCKen's Avatar
tks
You have to remove the cover off of the JB, not just the fuse access panel.
The #30 'fuse' is actually a 20 amp circuit breaker, #30. - in the upper right corner of the JB.
CCKen is offline
post #13 of 17 Old 06-17-2015, 10:00 AM
CCKen
CCKen's Avatar
JB Access:
Better pic of the JB.
CCKen is offline
post #14 of 17 Old 06-17-2015, 02:06 PM
Semperfi75
Yup, upon further research and using a mirror.. I notice that the box behind the panel is a smaller version of the picture above..More or less just the right side, but all the fuses are the same ones.. and.. Yes, the upper right hand #30 I also discovered was a 20A Circuit Breaker as you stated.. Changed, and also replaced Washer pumps anyway. All is back and in working order! Thanks to all.
post #15 of 17 Old 06-17-2015, 03:31 PM
CCKen
CCKen's Avatar
Good work.
CCKen is offline
2000 cherokee sport fuse diagram rbw26 XJ Cherokee Technical Forum 10 02-11-2016 06:06 PM
1997 - 2001 Fuse Panel Diagram 1997JeepXJ XJ Cherokee Technical Forum 5 04-15-2013 05:52 PM
Anyone have a Relay Box diagram for a 93 Cherokee? P3ngy XJ Cherokee Technical Forum 5 08-13-2008 11:18 PM
Needed 2001 Cherokee Sport Wiring Diagram Smokinbk XJ Cherokee Technical Forum 1 05-06-2008 05:03 AM
I need a 2001 Cherokee Sport Fuse Diagram Jeep4X4 XJ Cherokee Technical Forum 4 07-09-2006 05:43 PM
