Quantcast full packs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > full packs
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 04-18-2005, 08:49 AM   #1
Invictus
full packs
Where's the best place to pick up some RE 3.5" full leaf packs? Anyplace cheaper than straight from RE?
Rock Krawler: 3.5", Ultimate Steering, and Tie Rod / 35" MTRs / PSC Rock Brawler and various other whatnotery
Invictus is offline   Reply With Quote
Old 04-18-2005, 09:05 AM   #2
JIMBOJAMES
Why dont you buy the 4.5" leafs then you can really build up your Jeep, because the 5.5" kit only uses the 4.5" with shackles. You could add 1" spacer up front.
[COLOR="Black"]96 Cheorkee Sport - 6.5" Lift, with 33X12.50 BFG MT's, big bumpers [/COLOR]
JIMBOJAMES is offline   Reply With Quote
Old 04-18-2005, 09:41 AM   #3
Blake
Redefining body roll
Blake's Avatar
$300.00 for a pair from jeepinoutfitters.com (jeepin.com.):
http://www.jeepinoutfitters.com/scripts/prodView.asp?idproduct=348
$149.99 each at redrock4x4:
http://www.redrock4x4.com/shop/products/334.html
You could also give DPG Offroad a call and see what they can do for you. www.dpgoffroad.com
2005 G35 Sedan
Sport Package | Mostly Stock
1999.5 Ford F250
6.8l V10 l Auto l 4WD l 4" Spring Lift | 4.30 Gears | 35" Treadwright MT/R's
1987 Mercedes 300D Turbo
Stock | European Headlight Conversion!!1!
Blake is offline   Reply With Quote
Old 04-18-2005, 10:26 AM   #4
Invictus
I considered goin with the 4.5 inchers but wasnt positive on the other components ill also need to upgrade beside the SYE which is on the way, plus $$$ is tiiiight.
If you have recommendations on what else I may need if I decide to go that way I'm interested. Thanks man.
Old 04-18-2005, 10:35 AM   #5
silverxj2001
having 4.5" leafs doesnt mean theat you are "really building up your jeep", if he went with the 3.5" leafs and an appropriate coil, trimmed and bumpstopped properly, and ran a good tire / wheel combo with the right amount of backspacing, his rig would have a lower COG and be way more stable on the trails
invictus, i run the 3.5" RE leaf packs and they pretty much sit level with my 4.5" RE coils and 1.75" daystar spacers
RE underestimates their lift heights, so be wary
i even got mine used and broken in
2001 2-door XJ prerunner
6.5" RE
33x10.5" BFG A/T KO
15x8" rockcrawlers w/3.75" bs
hannemann 6" bulge flat top fiberglass fenders
bilstein 11" travel 5150's
RE XD trackbar / frame mount
RE adj. LCA/UCA's
beard triple thick limit straps
rusty's steering box brace
truckfarm pre-runner bumper
intake / exhaust
procomp lighting
system... yada yada yada
[URL=http://www.cardomain.com/memberpage/437678/1]PICS OF MY XJ[/URL]
silverxj2001 is offline   Reply With Quote
Glock Forum
