Fuel system problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Fuel system problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Aluminum BumpersThe RuffStuff "I can't go to EJS" Sale!
Unread 04-18-2014, 03:12 PM   #1
Ajkub
Fuel system problem
1990 Cherokee 4.0
When key is turner forward fuel pump runs for three seconds. Then there is click sound under hood and pump stops. So it will not run or build fuel pressure.
Is there a relay, breaker, or switch some where? I can not find any thing wrong electrically.
Ajkub is offline   Reply With Quote
Unread 04-18-2014, 07:57 PM   #2
79chiefs
1988 XJ Cherokee
That is the way it is supposed to work. It is called priming. It sends fuel to the rail to build up pressure and then it stops until you turn the engine over. So when you start to crank the engine over it will start again.
79 FSJ Cherokee Chief 350SBC-SOLD_88 XJ Laredo I6 Auto 4wd-SOLD_92 XJ Laredo I6 Auto 4wd-SOLD
99 WJ Laredo I6 Auto 2wd-TOTALED still fathers DD till repairs are made
95 E34 540i-DD
79chiefs is offline   Reply With Quote
Unread 04-18-2014, 10:05 PM   #3
Project1
Yea ... Need more info ... Is it cranking but not starting, or not cranking at all. You got to tell us more?
Any codes? What's your fuel pressure?
Project1 is offline   Reply With Quote
