fuel pump resistor. - JeepForum.com
post #1 of 14 Old 12-16-2006, 02:44 PM Thread Starter
88wagon
fuel pump resistor.
what size is the ballist resistor for the fuel pump?
09 jetta tdi
97 tj 31's
98 xj ssv package
07 yaris hatchback
88wagon is offline
post #2 of 14 Old 12-16-2006, 03:40 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Either 0.8 or 1.1 Ohm will work. You old ballast resistor should be labeled.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 14 Old 12-16-2006, 03:45 PM Thread Starter
88wagon
I went with a 1.0, reason for changing is when i would sit in stop and go traffic it would run like crap like it was lean and stuff and i got out and felt it and i could barely hold my hand on it. but when the cool air would pass over it on the highway it ran fine. has anyone else had this same problem?
09 jetta tdi
97 tj 31's
98 xj ssv package
07 yaris hatchback
88wagon is offline
post #4 of 14 Old 12-16-2006, 03:52 PM Thread Starter
88wagon
I put the new resistor on it and its doing the same thing. do you think the fuel pump is going out, it has a dull hum to it maybe its drawing too many amps???
09 jetta tdi
97 tj 31's
98 xj ssv package
07 yaris hatchback
88wagon is offline
post #5 of 14 Old 12-16-2006, 04:25 PM
Matt Gertsch
www.lp.org
You probably just need a new sock. If you're going to tear into the tank though, you might as well replace the pump while you're in there.
post #6 of 14 Old 12-16-2006, 07:47 PM Thread Starter
88wagon
yeah I am going to replace it anyways because of the humming noise but I hope it fixes my hesitation when its hot.
09 jetta tdi
97 tj 31's
98 xj ssv package
07 yaris hatchback
88wagon is offline
post #7 of 14 Old 12-16-2006, 10:11 PM
Matt Gertsch
www.lp.org
If it is starting to hesitate when the engine is warm, take a look at your cat. See if it is rattling.
post #8 of 14 Old 12-16-2006, 11:15 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Check the terminal tabs - the resistance value should be stamped into one of them.
It wasn't on 1987XJ, and it was a voluntary recall late in the year. It was added for 1988 and later, due to Noise, Vibration, and Harmonics issues.
I've had two quit - I just make a jumper out of 10AWG wire, put it in, and call it good. It's a Jeep - it's supposed to make noise!
5-90
5-90 is offline
post #9 of 14 Old 12-17-2006, 07:22 AM Thread Starter
88wagon
yeah i could care less about the noise i just want it run good after sitting in traffic for more than ten mins. i've been meaning to check the cat just in case but it doesnt seem like it gets hot or anything.
09 jetta tdi
97 tj 31's
98 xj ssv package
07 yaris hatchback
88wagon is offline
post #10 of 14 Old 12-17-2006, 10:13 PM
96JXJ
I by-passed the one on my 92 with no problems. I don't notice any extra noise. JIM.
96@6 & 92@3
96JXJ is offline
post #11 of 14 Old 12-18-2006, 06:30 PM
dspilot
mine makes a loud high pitched electric buzz that can be heard over the engine running while sitting in the drivers seat. I also have trouble with it when it heats up....Is it going out? The jeep has been sitting in on spot uncranked for at least two years.
When angry, count four; when very angry, swear.
--Mark Twain.
dspilot is offline
post #12 of 14 Old 12-18-2006, 06:44 PM
xj BMX xj
1992 XJ Cherokee
mines fine and its loud as hell ia dont pay atention to it tho
92 Cherokee Trail toy. - 97 Cherokee Street toy.
XJcruiser: Crumple zones? I guess the other car will have to share those.
xj BMX xj is offline
post #13 of 14 Old 12-18-2006, 06:48 PM
dspilot
I know jeeps are supposed to be loud, but when a fuel pump dies................
--Mark Twain.
dspilot is offline
post #14 of 14 Old 12-18-2006, 07:11 PM
dspilot
is there any info on the forums for how to change a fuel pump in a 96? I see the one on a 97+.
--Mark Twain.
dspilot is offline
Fuel pump relay clicks, pump doesn't run RogerRoger XJ Cherokee Technical Forum 9 07-19-2015 10:41 AM
Fuel Pump Ballast Resistor Untouchable XJ Cherokee Technical Forum 10 02-04-2010 05:31 PM
88 4.0 auto fuel pump always runs.. regulator or pump? robdoggydog1 XJ Cherokee Technical Forum 11 01-29-2010 06:33 PM
Start but no run..ASD...ballast resistor...or pump relay? Laodicea XJ Cherokee Technical Forum 4 02-19-2008 02:35 PM
Fuel Pump ballast resistor wiring schematics? 88 cherokee KariGrrrl XJ Cherokee Technical Forum 9 07-29-2005 06:41 PM
