fuel pump replaced pressure still drops - JeepForum.com
post #1 of 2 Old 05-03-2009, 06:53 PM Thread Starter
fiddlin1
Hello-
I just spent 3 days changing my 1992 Jeep cherokee 4.0L 4WD
in tank fuel pump-
Reason I replaced it was for an abrupt drop to zero of fuel pressure
at the injection rail when the fuel pump stopped- was told pump check valve?
I figured this would stop the longer than average crank time
on start up?
The first pump I put in acted the same way- pressure dropped to zero
right after the pump stopped-
so I took it back and got another pump- assuming the check valve
in the new pump was defective- well--- the next new pump did the same thing-
Now-- I have changed the fuel filter- changed the fuel pressure regulator
on the fuel rail- I have check the injectors for leaks- no leaking injectors-
I pulled the fuel rail off the manifold- pressurized the rail- no leak-
I am told-- this Jeep should hold fuel pressure at the rail when the
pump stops- maybe a leak down of 1 lb per hour-
I have decided to live with the longer than normal crank time-
But- am wondering about maybe a check valve between the pump
and fuel filter- in line? anybody heard of such a thing?
Thanks
Mark
fiddlin1 is offline
post #2 of 2 Old 05-03-2009, 07:48 PM
RoscoeJ
Check your return fuel line ,back to tank, if this is clogged, or plugged it will not let fuel flow out for long or tends to syphon fuel back to tank when shut off ,I had this problem...... and it creates hard starts, this may not be the case with your problem ,but its just my guess,.it seems to be a common problem though.. Hope this helps
RoscoeJ is offline
replaced fuel pump and it still won't start ksturgio XJ Cherokee Technical Forum 8 09-19-2009 05:07 PM
Replaced fuel pump and it still stalls after getting hot...?? holiday5000 XJ Cherokee Technical Forum 4 12-13-2008 12:02 PM
who has replaced their fuel pump? ktmracer419 XJ Cherokee Technical Forum 33 10-18-2007 09:10 PM
Help! Replaced fuel pump and still no go!!! Bornwinnr XJ Cherokee Technical Forum 8 06-06-2006 05:54 PM
Replaced fuel pump t bell XJ Cherokee Technical Forum 4 01-30-2006 08:05 PM
