fuel pump relay location on 1987 jeep cherokee 4.0 - JeepForum.com
post #1 of 9 Old 12-08-2008, 04:58 PM Thread Starter
rgjeep
1987 XJ Cherokee
newbie to jeep cherokees....there are four relays on the passenger side of my 1987 jeep cherokee 4.0 which one is for the fuel pump relay...remember newbie please be kind. Thanks
rgjeep is offline
post #2 of 9 Old 12-08-2008, 05:22 PM
Jeds Sr.
Crap I can't remember..... One of them is for the AC. I don't know what the other two are for. The fuel pump kicks on for a second or two when you turn on the switch. Pull one at a time till you figure it out.
Jeds Sr. is offline
post #3 of 9 Old 12-08-2008, 05:47 PM
tangofox007
In my experience, those four relays are not always in the same order from one vehicle to the next. The fuel relay receptacle will have orange/black wires attached.
tangofox007 is offline
post #4 of 9 Old 12-08-2008, 05:53 PM
Jeds Sr.
I looked in the manual and couldn't find it.
Jeds Sr. is offline
post #5 of 9 Old 12-08-2008, 06:00 PM
tangofox007
post #6 of 9 Old 12-08-2008, 07:24 PM
tc90xjcherokee
1990 XJ Cherokee
Mine was always second from the front of the vehicle on all of my XJs.
tc90xjcherokee is offline
post #7 of 9 Old 12-08-2008, 09:11 PM
tangofox007
How many Renix Cherokees have you owned?
There is a picture in this thread that shows the fuel pump relay to be the third from the front:
http://www.jeepforum.com/forum/f11/cps-fuel-pump-relay-location-542307/
post #8 of 9 Old 12-10-2008, 07:29 PM Thread Starter
rgjeep
1987 XJ Cherokee
thanks guys that was very helpful. i am coming from Dodge and i am still learning about this little gem i got for cheap...
rgjeep is offline
post #9 of 9 Old 12-15-2010, 01:49 PM
ejoe
1987 FSJ Cherokee
High acceleration - unusual solution
My high idle was a mystery on my auto transmission, 4 litre engine. Seemed to happen when the Jeep was warm, but could be cold, seemed to happen after it was started later on after having been run in the last hour or so, but not always... I replaced the rotor, cap, plugs and wires, that seemed to help but not as much. Hunted down a couple of vacuum leaks, but...
Oddly enough, when the Jeep was hot the high idle was more likely to kick in - when cold (less than 50 degrees temp outside) there seemed to be no problem, but the idle was low. Again, confusing.
I can only offer what worked. I began to discover that when I was stopped on a hill, and moving from brake to gas managed to roll backwards a touch... then the problem of high idle would come back the next time I started it. 1500 rpm minimum, sometimes over 3000 rpm... and yet, as far as I know there is no vacuum line going to the transmission such as there was on the older GM transmissions that had vacuum assist on the transmission. Is there?
When I stopped letting the Jeep roll backwards on a hill (and, among other things, stop creating havoc with all the little check valves in the transmission relay) the problem went away after a while. This just does not make sense, but when the usual suspects are ruled out such as ignition, carburation, fuel injection problems, throttle linkage jamming, the ECM keeping the idle up because the computer thinks there is a problem, then the highly unlikely becomes plausible. If this sounds out there, than just keep looking for that vacuum leak or something.
ejoe is offline
Where is the fuel pump relay on a 1992 jeep cherokee? Eburgwheeler XJ Cherokee Technical Forum 1 08-22-2009 08:41 PM
1987 jeep cherokee fuel pressure briansj10 XJ Cherokee Technical Forum 7 04-04-2009 07:12 AM
Suck at work, dead jeep. Does the fuel pump have a relay or fuse? chainerx XJ Cherokee Technical Forum 21 02-05-2009 12:56 AM
CPS and Fuel pump relay location? wann495909 XJ Cherokee Technical Forum 5 04-07-2008 03:41 PM
location of fuel pump relay in 88XJ? wgregoryt XJ Cherokee Technical Forum 9 03-16-2006 12:08 PM
